Question about HSM 125.2hs Shredder
Externally mounted oiler leaking around the seal. Can I get a rebuild kit for it
  • 41 Answers
Yes cooksmobileshred@bellsouth.net
Posted on May 11, 2010
Pump is leaking around the plastic plate on the suction side-possible seal problem?
call local pool service centers ask if the rebuild spa pumps, do the sell rebuild kits for that pump.
www.ask.com/mfg.name/make/model/authorized dealer and service center/
www.wikipedia.org/mfg.name/make/model/pump_recondition_unit/
/repair_shops_services
Apr 22, 2015 | Pool & Spa
My Maytag A9700 is leaking from the bottom of the outer tub. I have changed both the tub bearing and the stem seal but it is still leaking - even more than before I started. My question is whether I
If the boot seal was properly seated onto the outer tub lip, then you should focus on the water seal (#39 in the graphic - it should have come with the mounting stem kit) as the source of the leak. Extra care must be used when installing this over the agitator drive shaft - some recommend adding a lubricant (Maytag center seal grease works well) to the shaft before sliding the mounting stem (and water seal) down onto the agitator shaft. Also, check the two sealing surfaces where the top of the boot seal (#40) meets the bottom of the mounting stem (#30). Look for cracks, chips or any bits of debris. Anything that keeps those two surfaces from meeting perfectly will cause a leak. These repairs should go fairly smoothly, but leaking water seals and chipped boot seals can cause problems.
Dec 06, 2014 | Maytag Washing Machines
My 2003 1200 sports. after a good warm up about 20 miles the oil leaks about a 10 in. dia. under the bike
DETERMINE WHERE THE OIL IS COMING FROM (very easy on that bike). If it is dripping down from the air cleaner assembly, check to see that the oiler hole for your air cleaner isn't overproducing (common problem and easily dealt with). All Sportys from that era mark their spot to some extent due to the breather/oiler. Just make sure that it is not a crankcase leak. If it is a crankcase leak, simply replace the offending gasket or seal.
Also, check to be sure that it is not a brake fluid leak (less common but VERY dangerous for you), and check the seals around the shifter shaft to make sure they're not compromised.
Jun 24, 2014 | 2003 Harley Davidson XL 1200 C Sportster...
Air is leaking from regulator knob on my d55146 compressor. will a regulator rebuild kit fix it or do i need a hole new regulator?
Yes. A rebuild kit will include all seals and o-rings needed.
This project is best handled at a service center...Reason being that the rebuild requires making sure that all seal surfaces are a clean machine surface to properly reseat and seal..
Apr 20, 2013 | Dewalt D55146 1.8 HP Continuous, 200 PSI,...
Hi, got a bostitch N80 that performs ok but leaks air around the 1/16" gasket at the end of gun, also some air out the barrel. would a rebuild kit be advised and where would you suggest? JIM
The rebuild kit # ( ork11) is available on ebay or here:
http://www.mendingshed.com/ork11.html
This kit may not have all the orings but does include other parts needed. There are other kits available on ebay that would include all the orings but missing other parts.
Sometimes all you need is to open gun and clean orings and contact surfaces and lube with silicone paste (sold at Lowes in the plumbing department used to lube faucet orings). The cylinder seal on top of the cylinder and orings at cylinder spacer is usually cause of leak at nose of gun. Good luck
Oct 05, 2010 | Stanley Bostitch F21PL Nailer
Maytag Dependable LAT8824AAE. Main tub seal leaks
The part number for the mounting stem and seal kit is 6-2095720 it cost about 85 bucks retail. You will also need to buy a special maytag spanner wrench to remove the inner tub. Its NOT an easy job the inner and outer tubs and hoses all need to be removed. The seal kit comes with no instructions. If you had a service company do the job it would be probably around 250 maybe more. We charge 104.95 labor for the job. Good luck _MJ_
Mar 04, 2010 | Maytag Washing Machines
Leak inside Bostitch N80 Nailer, won't drive nails
If the unit is leaking it most likley need a rebuild kit. Go to a Bostitch service center and ask for an ORK-11 kit. That is all the o-rings needed to do an over haul. Or just have them do it.
May 23, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Senco sn2 air leak around out top only when the trigger is pulled
There is a cracked seal on the firing valve. It looks like it cant be replaced but it can. Look in your parts breakdown .It seals the firing valve to the cylinder
Apr 08, 2009 | Air Tools & Compressors
Clutch fluid is leaking inside of the car 240sx
You need to rebuild the seals in the cluth master cylinder. The seal around the pedal shaft that actuates the clutch is leaking fluid past the seal and onto the shaft connected to the pedal, inside the cabin.
A good parts store should be able to get you a seal rebuild kit, or remove the cylinder and bring it to a clutch shop or Nissan dealer and have them rebuild it for you. This is cheaper than dropping the car off and having them do all of the work.
Dismantling the master cylinder, replacing the seals, filling the system with fresh fluid and bleeding it should solve your problem. Be sure to replace all of the seals at one time, and don't be tempted to only replace the one that is leaking at the moment. They should all be the same age to last without further leaking. Otherwise you'll be chasing a series of problems with your clutch as the other old seals fail over time.
Hope this helps.
Dec 19, 2008 | 1990 Nissan 300ZX
HSM 125.2hs Shredder Logo
48 people viewed this question
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
ka4iup
ka4iup
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
