Question about Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio.. model wtw6400sw2 HC code appears on the screen. could hoses be hooked up bckwards. hot to cold etc ?
jsrock516
  • 5911 Answers
SOURCE: GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
Posted on Apr 29, 2007
duby1990
  • 370 Answers
SOURCE: code f50
It has a faulty control board. sorry but this a bad part from the factory. There is class action lawsuit against whirlpool about it. Call and complain and then maybe they will pay to fix it.
Posted on Nov 19, 2008
canbruce75
  • 1776 Answers
SOURCE: maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Posted on Aug 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool CABRIO WTW6400SW2 Washer shows F1 code
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Sep 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Cabrio Model WTW6400SW2
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Posted on Sep 28, 2010
What does "HC" mean?
The HC code indicates that the computer thinks the cold water inlet is getting hot water. The hot water inlet has the cold water coming in. Take off the inlet hoses and double check your water lines. If needed, swap the connections. While you have the hoses off, clear the filters and check for leaks. Check the flow rate and replace the hoses if the water flow is restricted. (Anti-burst hoses can reduce the flow when they detect a leak.)
If the hot water supply is correctly connected to the hot water inlet, then the electronic control board is getting faulty information. Unplug the washer for several minutes. If the code repeats, then the valve may be faulty. Alternative causes of the problem are the hoses, the wiring or the control board.
I hope this helps.
Mar 16, 2016 | Whirlpool WTW6400SW Cabrio Washer
HC code shows up after washing cycle is over
HC flashes when the hot and cold inlet hoses are reversed.
Make sure inlet hoses are connected correctly.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Aug 25, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
SYMBOLS ON THE PANEL
That means that you have the hot and cold hoses hooked up to the wrong inputs. Switch them.
Feb 02, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Platinum water is coming back out of the hot hose
You have a hot , cold and a mix valve ,I would suspect that the mix valve is stuck, try tapping on it
Whirlpool W10372095 Valve AppliancePartsPros com
May 26, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio washer shows a code HC...what does this mean?
HC will flash when the hot and cold inlet hoses are reversed. Make sure your inlet hoses are connected correctly. That should correct the issue.
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio WTW6400SW2 has a F50 error. I
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^&
May 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LOOK ON WIRLPOOL.COM AND LOOK UP CODES HIT THE CLEAR BUTTEN FOF35 SEC
Apr 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does HC stand for?
According to the Whirlpool "Cabrio" washer installation and maintenance manual, (Cabrio is the Sears Oasis) the HC code will come up when.
“HC” (Cold and Hot hoses switched)
cycle to indicate that the cold and hot water
inlet hoses are switched. If an error code
does not appear, but you are experiencing
poor washing performance, check to see
whether the inlet hoses are reversed. See
“Connect the Inlet Hoses.”
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6400SW Cabrio Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De
