Question about Western Digital 500GB MyBook Office Edition 500 GB USB 2.0 Hard Drive
I am in Europe and I used the wrong adapter to plug it in, even though it had a power converter built in. And, now it's fried, but I am wondering if the hard drive itself is ok, and I can send it in for repair and someone can replace the power supply? Preferably to a European one? thanks!
    President:
  • 2,992 Answers
The drive itself is probably safe. The power circuit board inside is usually toast when this happens. But given the low replacement cost of these external drives, it's probably not worth trying to get it repaired. I don't know if anyone besides the manufacturer would even try to service this. The cost of parts (if they can be obtained at all) and labor might approach that of a new drive. WD may offer a flat-rate repair service (likely they would just put your drive into a new housing), but I've never checked. Their website should list service options.
Your best course might be to remove the drive and check it by hooking it up in your computer. If it survived, order an external drive case from any of many online sources and put the drive into it. Otherwise you haven't wasted any more money on a repair.
Posted on Feb 01, 2010
Howw do you make a Samsung bd-F5700 blue ray player operate on a 240 volt power supply
You'll need to bring the voltage down to 110-120 volt. Travel converters do this cheap and effective. The player only uses 12 Watt according to the manual. You could use an old 3 prong extension cord to cut of the connector to connect to your power supply. Get the converter below and plug it into the adapter, who then will fit in the extension cord.
25361686-pcx3svhkvlazjixsdsr3jt1v-2-0.jpg New 220V to 110V Step Down Voltage Converter 50W Travel Power Transformer 25361686-pcx3svhkvlazjixsdsr3jt1v-2-3.jpg Generic Round Europe to USA Plug Adapter
Jan 09, 2015 | Samsung Televison & Video
Wrong voltage fried
Get a new power adapter for your N64 and try to find a power socket in your house that has 120v
Feb 28, 2014 | Nintendo 64 Console
Is a power converter needed in europe? Or can I just use a plug adapter.
Have a look at the label on the power adapter, if it supports 110 - 240 volts then it will be OK.
Mar 12, 2012 | ASUS Eee PC 1000HE Netbook
We had a power outage last night, and even though the adapter was plugged in through a surge protector, the console will no longer turn on, acts as if it is not getting any power. I have tried multiple...
Try using a friend's power adapter just in case yours got fried. If you don't know anyone that has a wii you can buy new adapters at stores like Gamestop for I think $20. If it doesn't work they have a policy now where you can return them even if they're opened within 7 days. If a new adapter doesn't work then your wii may be fried. Try calling Nintendo and see if they can do a repair for a cost, or if you are still under warranty and if they'll cover you.
Mar 31, 2010 | Nintendo Wii Console
I'm going to Europe and wanted to know how to convert electricity so when I plug in my computer it won't fry the computer
This is a copy from the Radio Shack site. The quick answer is go to pretty much any electronic store or most travel stores and buy a Foreign Power Converter.
AC to AC Power Conversion (Foreign Voltage Converters) Purpose of Converter / Explanation of Operation AC-to-AC voltage converters, or travel converters, are designed to convert the voltage used in a foreign country to the voltage required for a particular AC device. These converters are either transformer-based or solid-state, and this affects what type of devices the converter can power. In addition to converting the power, you will often need to also use a plug adapter. Plug adapters are generally either built into the converter, or provided as separate parts. They are also sold separately, for use with multi-voltage devices that are designed to convert the power internally.
Selecting a Converter These are one of the more confusing of the power conversion devices. Because of the range of voltages, plug types and converter designs, many customers find that they need help determining exactly which converter they need. To aid in that process, we have put together a short worksheet to help you determine what type of converter is needed: We recommend that you print out thi sheet when taking a number of different devices to a different country.
First, you should determine the electrical requirements (voltage, frequency, and wattage) for the device(s) you will be taking with you. This information is generally on a label or embossed into the back or bottom of the device. Make a note of the voltage(s), frequency or frequencies, and the wattage indicated for each device.
  • The voltage may be given as either V, VAC or VDC. The standard voltage for US devices is 120 V. Devices that are designed to operate using different input voltages will be labeled, such as 110/120 V, or 120/240 V.
  • The frequency will be given in Hz. The standard frequency for US devices is 60 Hz. Devices that are designed to operate using different frequencies will be labeled, such as 50/60 Hz.
  • The wattage will be given in either watts (W) or volt-amps (VA). If the wattage is not listed on the device, you will need to contact the device's manufacturer for this information. If you have the maximum current consumption (in amps), you can calculate the wattage by multiplying the voltage (V) times the current consumption (A).
Next, you will need to know the electrical requirements for the country you are going to be visiting.
Next, you will need to compare your equipment requirements to the country's information to determine whether you need a Step-up or Step-down Voltage converter.
  • If your equipment accepts the voltage and frequency provided by the country you will be visiting, then only a Plug Adapter will be required.
  • If the voltage of the target country is higher than the voltage required by your device(s), you will need a Step-Up Voltage Converter.
  • If the voltage of the target country is lower than the voltage required by your device(s), you will need a Step-Down Voltage Converter.
Once you know what type of converter or adapter you need, consult our list of travel power conversion products to find one that meets your requirements.
Cautions
  • The AC outlet in many foreign bathrooms is for low-wattage devices only. To avoid damage to your converter and/or attached device, check with your host or hotel before powering a high-wattage device (such as a hair dryer) from this plug.
  • Do not use a voltage converter with electronic devices such as televisions, VCR's and computers unless the device indicates that it can handle both 50 Hz and 60 Hz.
  • Do not use heating appliances, such as hair dryers, irons and coffee-makers, on a transformer-based voltage converter.
  • Do not use non-heating electronic devices, such as calculators, electric razors and portable audio players, on solid-state voltage converter.
  • Do not use 110-120 VAC Surge protectors or Uninterruptible Power supplies on a 220-240 VAC system. Even with a step-down power converter, damage could occur as the two power systems are wired differently.
Sep 22, 2009 | Toshiba Satellite L305D-S5895 Notebook
Its fuzzy at the start and then resets over and over again
even though the adapters allow you to physically plug in the N64, the voltages/amps might be different. try to use a voltage converter, and please, don't let your N64 fry.
Jul 02, 2009 | Nintendo 64 Console
Can my Vantec NexStar 3 Hard drive SAVE?
You might want to take the drive out of the case and use and external drive connector to see if the drive still works.
https://www.amazon.com/Drive-Adapter-Converter-Optical-External/dp/B002OV1VJW
Sep 02, 2017 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Best way to use US-Bose SA3 amp in Europe ?
Bose say you should pay to get it converted because over time the slightly different power cycles can effect it, however it will still works fine if you change the voltage with an adapter - like I did!!!
Dec 12, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
Charging phone in Europe
Yes!!
Any adapter that accepts up to 220volts will work with just the plug end adapter. However if it only accepts 110 you will need to purchase a voltage converter.
Have a safe trip in europe!
Check out my blog at:
http://www.pchelpforanyone.blogspot.com
May 11, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Ps3 power
Try and find a better/different adapter, maybe one the is specific for the PS3 or gaming in general. Don't use one of those universal ones, could fry your PS3.
Not sure what kind of outlet/plugs you guys have out there (I'm in Canada, eh) but I've provided a couple of links that should help you out. Personally, NYKO is a great choice, quality stuff and they have lots of accessories for the PS3.
http://discoazul.co.uk/powercord-nyko-ps3-european-plug-adapter/product_info.php/products_id/3206
Due to the volt difference; Europe (220v) vs. Canada & US (110v)
you MIGHT also need a power converter. Check the console, it will probably be able to handle 110v-220v but double check to be sure. I have heard all kinds of answers and opinions about it but best to check your PS3 yourself. If it odesn't support both voltages then you will also need to get a power converter.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Western Digital 500GB MyBook Office Edition 500 GB USB 2.0 Hard Drive Logo
35 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
