Question about Konica Minolta magicolor 2300DL Laser Printer
How do I replace all of the cartriges...can only find the blue
    Scholar:
  • 42 Answers
On the console of the 2300DL press the "Menu Select" button, then the right arrow untill "Engine" is dispalyed.
Then press the arrow button down, selecting Engine.
"Change Toner SZ" will appear.
Press the right arrow button, and "Replace Toner" will appear. Press the down arrow, selecting this function.
Select the color you wish to replace by using the left and right arrows. When the color appears that you wish to replace, select it by pressing the down arrow.
The toner name will be displayed and size selection is made here. If toner size needs to be changed, use the left and right arrows to adjust this setting.
Once set, press "Select" button. The printer will rotate the cartridge inside to allow access to the toner you selected for replacement.
"Open Door Replace Toner" will be displayed.
Open the door and replace the toner. When the replacement toner is inserted and seated properly, close the door.
The system will load the replacement toner. If you have other cartridges to replace use the steps above to replace each one.
I suggest after you replace cartridges to use the built in calibration utility. To calibrate, switch the unit off, let stand for a moment then switch back on. The calibration process will start automatically.
Posted on Feb 02, 2010
    President:
  • 2,306 Answers
You can open the door and halfway up is a hole that you press a screwdriver in to press the lever inside while you turn the carousel by hand to the other cartridges, watch your fingers though, it likes to pinch
Posted on Feb 01, 2010
Blue error light
if the blue light is on it means that the blue cartrige is all most empty and you need to buy a new one to replace it, you can check the status of the toner if you click on the samsung symbol in your Taskbar on the bottem of your screen.
May 17, 2011 | Samsung CLP 300 Laser Printer
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
Print Cartridges failed
there is alittle circuit board (print head) on the bottom side of the cartrige this should match up to one in the printer be sure to remove the little blue sticker on the new cartrige and make sure the cartrige locks in to it's holder and is seated fully
Dec 22, 2009 | HP PhotoSmart 7960 InkJet Printer
It prints blue instead of green when i print. anything that should be green turns out totally blue. any help? i've reset and calibrated twice.
have you tried replacing the color cartrige if so then the printer may be broken and uses the wrong colors its uncommon but does happen
Dec 19, 2009 | HP LaserJet 3600n Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Need repair on a HP1055CM plotter in Toledo Ohio
it is all one assembly. You will need to call a technician.
Jan 06, 2009 | HP DesignJet 1050c InkJet Printer
Printing
Just replaced the blue (cyan) colour cartrige in my Samsung laser printer but it just comes out a light red colour!, help i followed the instructions to install my new carridge
May 26, 2008 | Office Equipment & Supplies
Colour printing
Is by any chance a third party cartridge?
Jan 13, 2008 | Office Equipment & Supplies
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Konica Minolta magicolor 2300DL Laser Printer Logo
293 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
