Question about Maytag PYE2300AY Electric Dryer
Maytag MDE7057AZW FRONT LOAD DRYER
MACHINE BUZZES WHEN WE GO TO START DRYER. DID ONE LOAD AND THEN IT DIED.
  • tommy204 Dec 22, 2008
    hello. I have a Maytag electric dryer (model MDG7057) and it no longer runs when I push the start button. Leading up to it just not running the symptoms that would occur were: when I would push the start button, there would be a brief moment of like a buzzing noise then it would start (almost like on older model cars when you would turn the key ignition when the car was already running). eventually the dryer just didn't start at all when I would pust the button.
  • 92 Answers
SOUNDS LIKE A LOCKED MOTOR OR THE BLOWER WHEEL HAS SOMETHING JAMBED IN IT (ie. SOCK OR BABY ANIMAL,IT IS COLD OUTSIDE)
Posted on Feb 22, 2008
Maytag epic z power button wont start machine
Maytag dryer. has no start check door switch. if not door switch then its your relay board that may be bad also check all stats.
there will be 2 at blower cage and 2 on heater assembly
The 2 on blower cage one of these are a resister stat has to be exact resistance or dryer wont start or will start and then shut off dryer b4 it is completed drying hope this helps there should be a cheat sheet paper work that will help you diagnose your problem fallow the steps if not with dryer can be viewed online
Jun 25, 2014 | Maytag EPIC MFW9700S Front Load Washer
Maytag Model SDG3606AWW slow to start, shrieks when running
T"he sound you are hearing is coming from the blower wheel.This is located in the front of the machine and can be accessed by removing the front of the machine, Getting the front off varies machine to machine, Once the front is off, you'll see the blower wheel in the front, and once again some models you may have to remove exhaust vent, in others just the cover of the blower wheel. This is an easy repair, no doubt. The part number is 56000
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 03, 2012 | Maytag Dryers
When dryer is turned on, just buzzes and won't start. It buzzes as long as the start button is held. The tumble section cannot be rotated by hand.
hi sound like you have a bad motor or something is in the blower going to have to pull dryer apart to see what going on jim
Oct 18, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Performa PAV1000AWW. Motor buzzes but does not turn.
Your motor has gone bad...
If
you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 13, 2010 | Maytag Washing Machines
Model #PYE2300AYW Dryer. Changed therm fuse. Died in 5 loads. Changed therm fuse/Hi limit. Died in one load. This is a fairly simple machine. Could op thermostat be taking all these out? Tnx
Your lint trap and/or ducting could be blocked. This will cause the machine to overheat and the thermal fuse shuts it off before it burns your house down.
Jan 30, 2010 | Maytag PYE2300AY Electric Dryer
Kenmore 417 44042400 Front Load machine Sears says does not exist
YOU ARE ABSOLUTELY RIGHT. THE COMPANY SHOULD HAVE KNOWN ABOUT THIS. HERE IS MY SOLUTION: GO TO LOWE'S HARDWARE AND BUY A WASHER AND DRYER THERE. BUY THE GE BRAND. 3 YEARS AGO, WHEN OUR MAYTAG WASHER DIED, WE BOUGHT A NEW GE WASHER BEFORE MY FATHER DIED IN 2006. BUT CHECK INTO THAT. MY E MAIL ADRESS IS CoolRod41@yahoo.com IF YOU FIND THIS IMFO HELPFUL. GOOD LUCK.
RODNEY
May 17, 2009 | Kenmore 43042 Front Load Washer
The dryer has power but the start cycle knob only buzzes
IF THIS MODEL USES THE TIMER TO START THE MACHINE BY PULLING OUT ON THE KNOB, I HAVE HAD TO REPLACE QUITE A FEW TIMERS FOR THIS PROBLEM. SOMETIMES BY MOVING THE KNOB UP AND DOWN AND SIDE TO SIDE WHILE PULLING WILL START THE MACHINE. IF SO, REPLACE TIMER.
Nov 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't start.
DISASSEMBLE MAYTAG DRYER
Jul 10, 2008 | Dryers
Maytag PYE2300AY Electric Dryer Logo
155 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
