Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Runs fine until it warms up then it acts like the chain brake is on and won't run
  • tackmaster22 Feb 01, 2010
    Gas model, yes I have cleaned the chain brake. McCulloch 3516, serial number is at home, I'm at work. It has been suggested I check the sprocket for wear that the chain may be slipping in a worn spot on the sprocket. Differant ideas, welcome.
  • dontbother10
    dontbother10 May 11, 2010
    Gasoline or electric? Have you cleaned the chain brake? How about a model and serial number?
    President:
  • 2,220 Answers
I am going to close this, you can continue to reply and I will continue respond to the best of my ability.
Actually the slipping clutch is a good likelihood. I might lean toward an abraded clutch face. I will post what I consider a pretty good removal method. A couple of other things that come to mind from your description are:
1. When it begins to give you trouble, check the oiler operation. If the chain and bar get hot they will bind.
2. Do the same with the sprocket nose. You should not need to remove the bar, loosen it, slide the bar tight against the drive sprocket, loosen the chain at the nose of the bar and ensure you can easily rotate the sprocket in the nose of the bar. I do not think it #2 but it is a possibility.
Your basic model number is 600035. There are 11-, 21-, and 22- prefixes used with 600035s. There are also a ton of suffixes with the 600035s. I think the suffix is on your saw immediately after the basic model number somewhere (usually on bottom of older Macs along with the serial number. The dash of the serial on older Macs is the prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
I chose this one as an example "22-600035-58" for an IPL
http://www.ordertree.com/modelinfo/MCC/22-600035-58-Mac-3516-IPL-211229-01/139.22-600035-58-Mac-3516-IPL-211229-01.1.59.1.html
I find these helpful when getting into an area of repair I am unfamiliar with. Also clutch parts are displayed and part numbers listed.
She has an outboard clutch and this is very help with removal:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you find a solution please post back with what the actual cause is. It helps me be more helpful the next time I encounter a similar problem. HTH
Lou
Posted on Feb 01, 2010
My 1984 300zx N/A is acting up where it'll start
How many miles are on it? Could be timing chain wear.
Aug 07, 2013 | 1984 Nissan 300ZX
Acts like the choke is stuck closed it won't stay started and runs ruff until engine warms up then its fine. What do i do?
Well the choke has an electric part that heats up and makes the choke open in a few minutes. As soon as the engine starts the choke should open about 25 percent by way of a vac pull-off.
You can take the air cleaner off and watch the choke while someone starts the engine cold. If the choke does not open after it starts, check the choke pull-off. You can also open the choke with a screwdriver to see if the engine clears up.
Jan 29, 2013 | 1987 Chevrolet Caprice
Runs but the chain won't move? Poulan
This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
Aug 28, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain won't move when motor running
Sounds like the chain brake is on, grab the hand guard and pull it firmly back to the top handle to release the brake.
Aug 17, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Husqvarna 359: Has run fine for 3 years. Now when first starting idles fine but as soon as it warms up idle speed increases enough to continually engage the clutch. Carb. setting have never been changed...
I think an air leak and she is running lean. Maybe time for some pressure/vacuum testing. Continuing to tweak the carburetor may camouflage a larger problem until the saw fails.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 05, 2010 | Husqvarna Chain Saw 20" Bar
When cold my 93 chevy rbenjamin harrisonuns rough
give a good tune up. if it still is acting up let me know
Oct 16, 2009 | 1999 Chevrolet Silverado 1500
McCulloch chain saw wont stay running after it warms up. I go to cut wood it start to bog down if i let go of the button it idles fine
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a '69 E Type with stromberg 175 cd-2's that are causing problems when the engine warms to operating temperature. It runs fine when it is cold and then when it warms up it quits. When I try to...
Your problem is more likely a distributor-timing problem, than a carburator problem. The richness of the fuel acts like a constant choke, and the car runs fine until it warms up.
Once the car is warm, try manually advancing the spark. If that helps, then take the distributor to a repair shop that can tell you if the vacuum advance is working properly.
Remember, the spark must be +10 degrees advanced when cold.
Good Luck
Jul 25, 2008 | 2006 Jaguar XK-Series
Engine surges when cold - Once it warms up it runs fine
If carburated, I would suspect a sticking choke, making the fuel mix way too rich.
Jul 02, 2008 | 1997 Jeep Cherokee Country
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
267 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
