Question about Microwave Ovens
I have a built-in hood with VIV600 interior blower made by Viking Range corp. that had been working well since 2003. However, a few weeks ago, the blower stopped working. the lights are OK and we could still hear some noise when turning on the Fan/blower, but it's just not sucking any smog out. Can anyone provide suggestions on what to do?
  • xjpeng2004 Feb 01, 2010
    Did you mean visually checking out the parts? Do I need to turn the electricity off? How do I know which part is damaged? thanks.
  • xjpeng2004 Feb 02, 2010
    This suggestion has not solved my problem yet, but it points me to the right direction. I will check the problem again myself and get a professional help if the motor did burn out. thanks.
  • 1,476 Answers
If you use this unit alot the fan motor is probably gone. If you can use tools, power the unit down and disassemble it to get to the fan motor. Check the motor for excessive play end to end and side to side. It should not move. If it does it has probably worn the bushings to the point that the stator and rotor are touching causing the motor to drag and not reach full speed. If that is the case I would get the information off the unit and go to www.repairclinic.com to find a new motor and install it. This should solve your problem. Let me know how you make out or if you need any more help.
hardrocko
Posted on Feb 01, 2010
  • Kim Yearick
    Kim Yearick Feb 02, 2010
    My diagnosis points to the fan motor being bad. As I stated if you are not comfortable disassembling the unit you should hire a competent technician but with a screwdriver and a little work it should not be that hard to replace the motor. Typically it is located near the rear with a couple of screws after the cover is removed. www.repairclinic.com should be able to supply the parts.Let me know how you make out or if you need any more help.
    hardrocko
  • 3,741 Answers
Check out the motor in the blower.if its making noise then check out for the motor bearings of the motor.its possible that motor coils are got burned inside. check out the motor coils, motor wirings and motor bearings. check out.keep updated.thanks.
Viking Hood Microwave and Convection oven quit - does it have a fuse in the oven?
Yes they do.
If you had listed the model number, we would likely have been able to point you to the appropriate Sharp service manual.
(Viking microwaves are just rebranded Sharp models with enhanced cosmetics)
Aug 14, 2013 | Viking Microwave Ovens
Sears Canada bought Eatons Canada back in 2002. Eatons sold Viking products. I bought I Sears Viking over the range Viking microwave built in 2002. Nomeclature # 851.8250800 Model # 82508 Ser#...
This is a Sanyo microwave. the "851" number is the manufacturer number or "source" number. I can't tell you any more about that particular model.
I would remove the circuit board (control panel) and check for damaged/burnt copper print. Where the copper is burnt, you can solder on jumper wires to complete the circuit.
Mar 01, 2011 | Kenmore 80492 / 80494 / 80499 1000 Watts...
A few weeks ago our ge JVM1660 quit heating and ge sent me a replacement magnetron. I've heard that the capacitor will discharge after the unit has been unplugged for 24 hours... Mine has been unplugged...
Hi newer microwave ovens have a built in resistor to bleed the power from the capacitor once it is unplugged. Saying this it is always a good safety practice to discharge it.
The factory approved method is to purchase a 2 Watt, 20,000 ohm resistor and touch it across the terminals on the microwave capacitor to discharge, doing this with a tool like pliers so you are not touching the metal tips of the resistor.
Most technicians will use pliers that have insulated handles and touch the tips to the capacitor. I am not condoning that, just letting you know.
May 09, 2010 | GE JVM1660 Microwave Oven
Kenmore Microwave -SE- code
I have the same problem with my microwave and i cant fix it help?
May 10, 2010 | Kenmore Microwave Ovens
Whirlpool MH2175XS microwave/hood combo with oil leak, etc.
This is a very wierd problem that we have been dealing with for years, and never seem to get a correct answer. Have actually seen green slime like oil inside the units before. From what we have heard, is that this oily substance is actually coming out of the blower fan assembly inside the unit. Its like bearing oil from the center support shaft. Will go away over time, but the fan may or may not go bad. Good luck with the mystery oil.
Jun 11, 2009 | Whirlpool MH1150XMQ Microwave Oven
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
Vent fan runs intermittently, starts on and off regularily
I don't have the manual but there should be a temperature setting for the fan to come on.
Jun 23, 2007 | Bosch HMV9305 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
