Question about Royal Office Equipment & Supplies
Can you purchase replacement blades for RL170MX Paper Shredder?
    Genius:
  • 1,218 Answers
For parts give Royal a call at 1-800-524-0799..they should be able to help.
Posted on Aug 22, 2010
My shredder squeaks when in use, does it need regular lubrication? If so, what do I use?
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
Feb 20, 2012 | Royal Sc120 Shredder
Can the head(cutting assembly) be replaced? purchased?
Contact ROYAL at 1-800-524-0799 regarding replacement parts and pricing.
Jun 08, 2011 | Royal RL170MX Shredder
My shredder Royal RL170MX is not working,makes noise and everything,turn on but the paper is not going in,what can i do
If the motor sounds like its running but the cutting shafts are not turning then you have likely stripped the teeth off one or more of the plastic gears inside.
Take the unit apart to determine which gear/gears are damaged the contact ROYAL at 1-800-524-0799 for parts assistance.
Jan 29, 2011 | Royal RL170MX Shredder
My RL170MX will only run in reverse mode. Forward and auto modes do not work. What controls the motor rotation ?
Motor forwards rotation is begun by inserting paper in betwen the 2 "eyes" in the paper throat of the shredder. They can become dusty/dirty and not function, if they are clean and yet the motor still will not turn in the forward direction it is possible the pcb inside the unit is faulty...contact Royal at 1-800-524-0799 for parts assistance.
Nov 12, 2010 | Royal RL170MX Shredder
I have a Royal RL170MX shredder. It has started
Try putting some oil on a sheet of paper and then shredding the paper with oil on it.
If that dosn't fix it....take cover off....(with the unit unplugged.) and check plastic gears in drive train.
May 20, 2010 | Royal RL170MX Shredder
Royal RL170MX shredder blades do not turn -- seems stuck.
you have 1 or 2 broken drive gears.I don't know if they made replacement parts for that model, try calling 1-800-272-6229 (royal customer support).
Dec 01, 2009 | Televison & Video
I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
Sep 01, 2009 | Royal Office Equipment & Supplies
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
71 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
