Question about Chamberlain 956D Remote Control
Need the 956D remote to learn the TRICODE TC1-1006 code
I have a TRICODE TC1-1006 (set to Multi) 1-button gate opener and a 956D 3-button mini remote. How do I program the 956D 3-button mini remote to learn the TC1-1006 1 button tricode and open said gate? Or program the 956D 3-button mini remote to open the same gate using one of the other 2 side buttons.
Can I push the TRICODE TC1-1006 button and have the 956D 3-button mini remote learn the code that way?
Is it even possible for the 956D 3-button multi-function mini remote to open that gate?
  • 341 Answers
I would suggest going to Chamberlain-diy.com/doityourself/support/programminginstructions. You will be able to enter your remote control model # and check out how to program it. Browse the rest of the web site to see if anything else is helpful in your situation. I believe that you will have to check out either the gate openers manual or go to their website and see if it is possible to accept codes from your chamberlain remote. Good Luck! P.S. Hope this is a little helpful to you!
Posted on Feb 01, 2010
How do i program my lexus 2001 rx300 for a gate opener
You should see three buttons on the driver sun shade. Let's name them from left to right 1,2, and 3. Start by clearing any old codes. To clear codes press buttons 1 and 3 simultaneously until the light starts blinking. Release the buttons simultaneously. Before starting to program the car remotes you must have your gate hand held remote ready with a good charged battery. Now, to program your first gate car remote let's choose button 1. Press button 1 until it start blinking (about 20 seconds). Keeping button 1 pressed, activate your hand held remote close (about an inch) from the car button 1, until the light blinks faster than before. Release both remotes simultaneously. You are done programming your car remote button 1. For two additional gates remote controls programming repeat the procedure with button 2 and then with button 3.
Nov 13, 2010 | 2001 Lexus RX 300
How to use 2 button remote for two mighty mule gate openers
I understanding that the chamberlin is a two button remote so as long as you have the same kind of recierver (a box hooked up in your operator that has dip switches,it recieves signals when the remote and it are set the same.) you should be able to use the two button remote on both machines. If not their is a reciever that is called multi-code and it is universal to work with all gate openers. the chamberlin remote you have will work with it.
Feb 23, 2010 | Chamberlain Clicker Universal Remote...
PROGRAM PRIUS GARAGE DOOR HOW DO I PROGRAM THE BUTTONS ON THE PRIUS' REAR VIEW MIRROR TO OPEN THE GARAGE DOOR
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing)
- Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me)
- locate the "learning button" on the opener itself
- press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall.
- Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener.
Oct 30, 2009 | 2007 Toyota Prius
Unable to program my new 2009 Altima Hybrid Homelink to my gate
The Learn Button is in a Silver little metal box that is in the opener housing but separate from the opener itself, pry off the case which kinda wraps around the reciever, it will say liftmaster of chamberlain the learn button will be in the reciever
Apr 05, 2009 | 2008 Nissan Altima Hybrid
Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
moz-screenshot.jpgmoz-screenshot-1.jpgRegion
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
Feb 28, 2009 | Philips Televison & Video
Liftmaster MJ5011 jackshaft opener
look for learn button. push for 1 sec. type in code and hit enter. should work
Nov 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Need to change my Crown CDV 1100B player to multi region, have tried recommended options from other sites, but to no avail. This what I've tried so far. 1) Press set up 2)press 1369 (which was...
a) Press SETUP button on the remote control to display the setup
screen
b) Press "1369<<<>" on the remote control ( "<" = left navigation
button; ">" = right navigation button)
c) A new item "VERSION" is added on the menu
d) Select thr VERSION item and press SELECT button to enter
e) Press the right navigation button ">" on the remote control to
change the region code
f) Press SETUP button again to exit the region code change mode
Note: Region code 0 is "all region code".
OR
1.press eject to open the draw.
2.type 9-8-1-7.
3.press select to go through regions.
4.change to region 9 for multi region.
5.press eject to close the draw.
OR
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the 8, 4, 2 and 1 buttons on your remote control, in order, one at a time
3. Press the Enter button on your remote control until the hidden menu appears
4. Select 1 for region 1, 2 for region 2, and so on, or All for multi-region
5. Press the Open/Close button on your remote control
To alter the Macrovision settings on this player
1. Press the Open button on your remote control to open the drive tray
2. Press the 4, 5, 6 and 1 buttons on your remote control, in order, one at a time
3. Select Enable to enable Macrovision, or Disable to disable Macrovision
May 03, 2008 | Televison & Video
Setting region codes to code 1
*To convert this player to Multi-Region
1. Open the drive tray
2. Press the Setup button on your remote control
3. Press the buttons 1, 9 and 9, in order and one at a time on your remote control
4. Select the Region option from the menu and change to a specific region or all regions
To convert this player to Multi-Region if the above does not work
1. Press the 7 button on your remote control
2. Press the 6 button on your remote control
3. Press the Select button on your remote control
4. Highlight the Region option and press 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
5. By visiting the next page of this hidden menu, you may be able to disabled Macrovision by setting an option to 0, although this particular setting does not survive power off
6. Press the Setup button on your remote control
Done!
Oct 18, 2007 | Pioneer DV-373 DVD Player
Chamberlain 956D Remote Control Logo
110 people viewed this question
Top Chamberlain Televison & Video Experts
Raj Patel
Are you a Chamberlain Televison and Video Expert? Answer questions, earn points and help others
