Question about Epson Stylus CX3200 All-In-One InkJet Printer
Need help can't print have a compaq laptop and cx3200 won't load have no disc help when going to web from assistance it wants to load on an M drive I don't have. Need my printer please help
    Problem Solver:
  • 10 Answers
Hi
try to download the file from support.epson.com, make sure you selected the driver for the specific o.s.
save it to the dekstop and open the file from there. during the installation make sure that your printer is not connected. you should be good to go from there..
Posted on Feb 23, 2008
I bought a new hardrive for my m2000 and when i load it it is giving me a "media test failure" response..... how do i load it properly?
If you bought a new hard drive (meaning the internal hard disk), it won't have anything on it. If you just install it and try booting your computer, there won't be an operating system to load. The BIOS (the operating system built into the motherboard) is set up to try loading the operating from connected devices in a certain order. Usually it tries the optical drive first, then the hard drive, and finally it tries to boot over a network connection. The media test failure message means it tried that last resort and still didn't find an operating system, and it's telling you that maybe you have a bad network cable.
You'll need to reinstall your operating system and applications so that the computer will start normally. If your computer came with a restore disc set, or you made a set yourself, you'd use those. If you don't have restore discs, you can do a fresh installation of Windows from CD. You need to find the disc for the version that came installed on your computer, since you'll need to use the product key from the sticker on the bottom. Drivers and utility programs you can download from Compaq's (HP, actually) support and drivers website.
Once you've got a bootable Windows system on the new drive, you won't get that strange message any more.
Jun 03, 2011 | Compaq Presario M2000 Notebook
Need a recovery disc! i recently bought one with a completely erased hard drive. i have xp software and key dut need to recover disc prior to loading. any help?
If HP/Compaq cannot supply you with a recovery disc, then you can get around this.
Install Windows XP then download the device drivers for your model laptop and install them on your laptop. You can use a another computer with Internet access then copy and install them on your laptop.
Normal 0
You can download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Oct 09, 2010 | HP Compaq Presario C304NR Notebook
COMPAQ PRESARIO M2000 RECOVERY DISC WILL NOT LOAD ON NEW HARD DRIVE
The issue here to be quite frank is the hard drive needs the compaq image before the recovery disk can be loaded. This provents people from taking there compaq disk and getting wise and installing it on multiable computers what authors call piracy.
What you need to do is have compaq NOW HP send you out a IMAGE recovery disc usually when a hard drive crashes they send you out the hard drive with the IMAGE.
The other solution is purchasing windows 7 upgrade and going at it from there.
Thanks hope this helps please do not shoot the messenger and leave postive feedback and ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 11, 2010 | Compaq Presario M2000 Notebook
Have compaq evo n610c laptop, it locked up on
sadly you need a new drive, these are about £40.
from any computer vendor fit new drive and then load installation disc.
hope this helps.
Apr 27, 2010 | Compaq Evo N610C Notebook
An information loading disc has disappeared and I can't retrieve
ok there is a tiny little hole in the front of the dvd drive, insert a pin into it, this will manually open the drive
Jun 25, 2009 | Compaq Presario 1700 Notebook
Help
Go and buy an exrenal CD/DVD drive for it. Good Luck. the Yeti
May 19, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Won,t print
Take it back and buy an Epson brand.
Feb 05, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My compaq n410c won`t start ,it get viruses.. need help
A friend clean the hard drive and load a fresh windows xp...
Thanks
Jan 22, 2009 | HP Compaq Evo Notebook N410c
Compaq Armada e500 won?t recognize the cd drive
Simple things first: Assuming the CD drive is removable, remove it from the laptop then re-iinsert it making sure it's pushed home properly so that the connectors seat properly.
If, again, the drive is in a bay (i.e. it's removable) then it may be the connectors are worn/damaged. If it's the drive connector then it may be repairable or you might pick up another drive, perhaps on eBay. It may also be that the drive has simply given up the ghost - so back to eBay :) If the connectors on the laptop have got damaged then you're looking at dismantling the laptop to repair/replace them, if that's possible.
If it's an external drive then the advice is very similar - check out the connectors first. If they look OK then you probably have to suspect the drive itself.
For either type of drive, there is always the small chance that the IDE controller channel on the motherboard has died - I have seen this happen in rare cases. Your options then are a bit limited. IIRC, that PC has no USB2 and even if it did, it wouldn't boot from a USB CD. You can get a PCMCIA interface card (now called simply PC interface) for an external CD. Depending on the card-drive interface, you might be able to boot from that.
If you need to install software onto the machine & have another (desktop) PC to hand: remove the disc from the E500, get a 2 1/2 to 3 1/2" disc adapter & temporarily attach the drive to the desktop as a secondary (i.e. not boot) disc. You can then load software onto the drive although you can't do a Windows install that way. If the machine already has an old version of windows on it, you can copy for example, the XP install files onto the drive, put it back in the machine & run an upgrade. Not the most desirable result but may be OK.
Nov 03, 2007 | Compaq Armada E500 Notebook
Epson Stylus CX3200 All-In-One InkJet Printer Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
