Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
I bought a used truck with a bulldog remote starter in it but the guy has it set to start when it reaches a -10. I want to reset so only starts when I hit the button. The key fob looks alot like the rs 1100.
  • 344 Answers
PRESS AND HOLD THE BRAKE PEDEL, PRESS AND HOLD BUTTON 2 UNTIL PARKING LIGHTS FLASH 2 TIMES, RELEASE BUTTON 2 AND PRESS AND HOLD AGAIN UNTIL 2 FAST FLASHES ARE HEARD, RELEASE BRAKES AND LIGHTS WILL FLASH 3 TIMES, THERE ARE 7 DIFFERENT SETTINGS SO IT MIGHT A COUPLE SECONDS TO COMPLETE
Posted on Feb 02, 2010
Remote starter doesn't function
if the battery was replaced or any terminals removed, you may have lost the tach programming for the remote starter. Goto http://www.bulldogsecurity.com/bdnew/installmanuals.asp and look for the remote start unit you have in the manuals and it will tell ya how to reprogram the tach memory.
Jun 29, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Added remote starter on vw jetta 2004
No, this is not correct, did you have to give up a key, or did he use a bypass module, either way, you can check next time it won't start by putting your key into the ignition and leaving it in the off position, then try to remote start it, if it starts then your installer needs to reposition the transponder loop around the ign switch or reposition the "key in the box"
Jan 30, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Bulldog Remote Start Problem
if thats a key resisor bypass i never heard of that, i would check with with bulldog to see if may be a set upproblem
Jan 24, 2010 | 2000 Chevrolet Impala
Model rs1200 w/791 bypass hit start button runs 3 minutes then dies,starts by it self runs 3 minutes dies, starts by its self runs 3 minutes dies, use key starts & runs fine
check your documentation on adjusting the runtime for the unit. Normally they will run 15min. shutdown then restart run 15min. ect. also check the settings for use of a tach wire.
Dec 29, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Bulldog Deluxe500 in '02 trailblazer will not start or reset.
unplug all harnesses going to unit for 5 min plug all harnesses back in and reprogram remote, you do not need to program for voltage sense, that is the factory defalt or call tech support at 1-800-878-8007
Dec 16, 2009 | DLX 500 Remote Car Starter
2003 S-10 with intermitent no start
I would check to see that the red with white stripe wire, the orange with black stripe wire and the yellow wire have a solid connection. I thought they only made S-10 till 1994
Feb 07, 2009 | Bulldog Remote Starter & T-Harness Kit for...
No range for my Bulldog Remote Start.
Get a Viper 5900, it has a 1 mile + range
Or a viper 5601 has a 2000 ft range.
Bulldog is DIY and entry level stuff. You cant expect much from them.
The wire antennas work the best when they are stretched out. Not wadded in a ball or in a loop. If you have to loop it use figure 8's. Try streatching it up the "A" pillar and in the headliner across the top of the windshield. Also, do not ground the antenna, and let the end hang.
Also check your hot and ground connections. Make your ground at the kick panel sheet metal. Do not use a factory ground or a metal bracket in the dashboard. Do use a file or sandpaper to buff the ground site to the bare metal.
Guy
Jan 09, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Bulldog Remote Starter On 92 Blazer-Cranks but no fuel pump
I've wired several of these and you have likely hooked up the wires wrong its not giving power to the right wires at the bottom of your steering column...........re check your connections
on your truck there are 3 wires that need power for the starter to work they are the orange,pink and brown
hope this helps!
Dec 30, 2008 | Bulldog Remote Starter & T-Harness Kit for...
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
226 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
