Question about Whirlpool Ovens
The oven door does not close properly and stays open enough to keep the light on. Whirlpool Gold, Model GR399LX60
  • Whirlpool Master
  • 3,463 Answers
If it has a drop down door with hinge on either side, then only solution is to replace both door hinges, as the problem is usually due to weak door springs, and they are not adjustable.
Please rate my solution.
Thankyou.
Posted on Feb 01, 2010
Door is locked after self cleaning
Most ovens with self-clean cycles have a door lock to keep things closed when it ramps up the the extreme heat levels for cleaning. Usually, the door will stay locked until the thermostat sensor says that the oven is back down at or close to room temperature. If you just finished the cleaning cycle, you'll likely need to wait a while longer.
Nov 24, 2015 | Whirlpool Gold 30 in. Electric Convection...
Oven door does not stay closed tight enough to keep light off or to keep open door light on heating
Sorry to read about your problem, I hope this helps you out.
you have a spring/hinge problem. or a small chance, your door seal is defective.
you may try to remove the door and re-seat it...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Whirlpool RBS305PD Electric Single Oven
Door will not stay closed
Hello,Sounds like the door hinge springs are weak, it will probably be necessary to replace them both.
Thanks
Jun 02, 2010 | Whirlpool GBS277PDS Electric Single Oven
My whirlpool double oven lower door won't stay closed all the way. model RBD305PD810. is there an adjustment that is needed?
If it is a drop down door, then you need to replace both door hinges, if it is a door that opens sideways, then it is probably the door catch, or door striker that needs to be replaced.
Thanks.
Nov 01, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven not working properly
Two possibilities for you to look at:
i) Draughts can adversly affect the operation of an oven burner, close all doors and windows.......does this improve it?
ii)If the above doesn't work then you have either a fault with the incoming gas supply (rare) or there is a fault with a component called an FSD (Flame Safeguard Device) I would highly recommend a 'Gas Safe' engineer take a look at it for you.
I hope this helps.
Steve
Jul 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
The oven door on my Whirlpool oven won't stay closed
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 | Ovens
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 | Ovens
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Nov 22, 2007 | KitchenAid KEBC208 Electric Double Oven
Ovens Logo
301 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
