Dvd player won't quit scrolling even without disk
Cannot connect dvd-8150 to my sanyo hd ready tv by red white & yellow cables
Posted on Feb 01, 2010
Won't read the dc
First, Try another DVD to be sure its not just a scratched disk. Make sure the disk is spinning (you will hear and feel it spin up). If its spinning but still wont read you can clean the lens inside the DVD player with a air compressor or can of compressed air. The better solution would be to use a CD designed for cleaning the lens that read the DVD. They are quite cheap and are very nice to have around. If it still will not read then you are much much better off just junking that DVD player and buying another. They do not make replacement parts for DVD players and they are getting very cheap to replace. Good Luck. Thank You
~Kyle~
Aug 16, 2012 | Coby Televison & Video
Dvd player reads no disk..even though the disk is in player, i want to watch the dvd i rented now. help
Some rented discs won't play becauses of scratches and dirt, if other DVD 'S work it is not your player, but if all won't play try a DVD cleaning kit and follow instructions.
Mar 17, 2012 | Sony Televison & Video
Sony DVP-cx860 Disks won't feed from the carousel into the reader.
The thickness of DVDs and CDs often vary and the surfaces are too slick. Roughening the outer edge(s) of one or both side(s) of the disk was an immediate fix for the loading problem.
Jan 14, 2012 | Sony DVP-CX860 Multi-disc DVD Player
Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Aug 11, 2011 | Sony DVP-S360D DVD Player
My dvd won't play. every dvd i put in, it says bad disc. the vcr works fine. is it time for a new system. i tried a head cleaner and it says bad disc
Not necessarily time for a new one. I would give the DVD player a good cleaning before you consider a new unit. A good cleaning disk with some little bristles on it. Run it through three full times. DVD players are far more sensitive than VCRs and have to be cleaned even two weeks or so. When they get real dirty it can take some fooling with to get the DVD player to even accept the cleaning disk. But if it just won't accept the cleaning disk and you can't watch a DVD in it then it's time for a new one. I had a DVD player one time that took an hour of fooling around with before it got cleaned good enough to play DVDs. Worked for a couple years afterward.
Regards, Tony
Apr 19, 2011 | GoVideo Go Video DVD/VCR Combo
When i put a dvd in the player makes noise and screen says no disk or unable to read
Sounds like the mounting spindle is out of alignment, meaning the disks you load into the player are not spinning in a balanced, stable position. Without this being the case the laser pickup will not be able to read the disk and the unbalanced disk will cause a noisy hum and you may even be able to feel vibration in the player itself to confirm this. Sometimes the noise and vibration is a disks fault but if it occurs on any disk you insert (and can confirm the same disks work ok with no noise in other DVD players) it will be the players mounting mechanisim that is not playing the game properly I suspect.
Aug 18, 2009 | Polaroid DPA08055S Portable DVD Player
Dvd's won;'t play
The laser lens may need to be cleaned with rubbing alcohol and cotton swab. Just remove the cover of the player and clean the lens. This usually corrects the problem. If cleaning doesn't help, the laser is defective
Jul 01, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD will not load
Firs try to clean the lens with CD/DVD cleaning disk (it might be $1-5 depending on store)
Also check if DVD disk not upside down.
Also chek the DVD disk for scratches
Good Luck
Dec 25, 2008 | Daewoo DVG-9200N DVD Player
My dvd player plays avi files but now it wont play any dvd just dont read disks
The reading lens inside the player should have accumulated dirt or must have been corrupted in some other way. You can get lens cleaning kits and this problem will be solved easily.
this problem occurs quite often if the players are used for a long time, or left without usage.
Many cleaning products out there.. heres one.. click here
Apr 11, 2008 | Televison & Video
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
