Question about HP LaserJet 4700N Printer
Replaced the 4700 image transfer kit and am still getting lines through printed documents
    President:
  • 2,306 Answers
Lines can come from the drum cartridge, or even the fuser unit. You start a print cycle and stop or unplug the printer while print is partway thru. You remove the drum and see if the lines are already on it before fusing, If the lines are there you need a new drum, if not there you need a new fuser or fuser rollers.
Posted on Feb 01, 2010
    Sergeant:
    Champion:
  • 232 Answers
Hi jclaeys
Does the transfer kit include the fuser on this model? If not then it's highly likely that that's the part that needs swapping. I have also seen faulty toner cartridges produce lines so it's worth check that too.
Hope this helps!
Scott
Service error 4cf0 hp 4700
Try removing the JetDirect card, then see if the machine will boot and print a test page. If it works without JetDirect, then try replacing the JetDirect card.
Oct 15, 2014 | HP LaserJet 4700 Printer
How do I replace my HP Color LaserJet 4700 Image Transfer Kit? I don't have the manual for it.
Replace the ETB when a REPLACE TRANSFER KIT message displays on the control panel.
1. Turn the printer off.
2. Open the top and front cover.
3. Lower the ETB by pulling the green handle at the top of the unit downward.
4. Press the small blue latches located on either side of the bottom of the ETB and lift the unit out
of the printer.
5. Install the new ETB.
6. Close the front and top covers.
Apr 11, 2011 | HP LaserJet 4700 Printer
Hp 4700n laserjet printer. I get black dashes on the right hand side of the page exactly every 1 1/2" every time i print. I've replaced the infuser and the image transfer kit but still get the marks. What...
I would first suspect the black toner cartridge. This is especially true since you have replaced the Fuser and Transfer Units. Most likely you have a pit or other mark on the drum surface so it is printing the mark on the page at regular intervals as the drum rotates. If you have a spare I would swap it out and I'd be willing to bet it goes away.
Good Luck and Thank You for using Fixya.
Sep 29, 2010 | HP LaserJet 4700 Printer
My 4700dn is giving me the replace transfer kit message. I have swapped out known good transfer kits and the printer prints fine but I still get the replace transfer kit message. What can I try next?
The message only clears when you install a new transfer unit, one that hasn't been used before. If you want to clear the message, you'll have to install a brand new transfer belt.
If you know the service PIN for the 4700, you can probably go into the service menu and clear the message, but otherwise a new transfer unit is the only way to go.
Aug 11, 2010 | HP LaserJet 4700 Printer
My 4700 hp printer is double printing and giving a replace transfer kit notice
This means you'll have to replace the transfer kit because it is "end of live". This also causes the printing problems. The transfer unit is the big black unit you'll find when you open the front cover.
Jul 29, 2010 | HP LaserJet 4700 Printer
How to replace image fuser kit for hp laserjet 4700n
turn off the machine. open upper front cover. remove the old fuser and insert the new one. turn on the machine and enjoy your printer with new fuser kit.
Jan 20, 2010 | HP LaserJet 4700 Printer
How do i reset the transfer kit for HP LJ 4700
with the power on, press the down arrow button until the display reads " Configure Device" menu. Press the Select button and using the down arrow button, scroll through this menu until the display reads "Resets" and press the Select Button. Then press the down arrow button again until the screen reads "Reset Supplies" and press Select button. Once you get to this menu this is where you can reset the fuser and the Transfer belt count
Oct 06, 2009 | HP LaserJet 4700 Printer
4700 is printing a streak (like a scratch) across ppt
check transfer belt.open front door,see if any toner on belt.
Jul 07, 2009 | HP LaserJet 4700 Printer
HP LaserJet 4700N Printer Logo
624 people viewed this question
Seeker5211
Seeker5211
