Question about Magic Chef Dryers
I have a Magic Chef dryer, model YE20FN3 that works fine on low heat but not on high heat. I've cleaned all the duct work but still no high heat. Your thoughts would be greatly appreciated
  • Dave Lindstrom
    Dave Lindstrom Feb 01, 2010
    a second opinion would be appreciated
  • 3,741 Answers
If you're only getting low heat this implies one of the following:
- loose/corroded/damaged connector, or
- bad thermal limit switch/tstat
you will have to check out this possibilities by testing it from meter and continuity tester. Probably element only working on low heat. check filter and outlet . No heat or low heat is the third problem and probably the most common problem with dryers. The places to check for this problem on an electric dryer are: Power supply-Heater element-thermal fuse-heat select switch-timer contacts for heat circuit-high limit and control thermostats, and the motor run safety switch. These tests can be made with an ohm meter with the dryer unplugged. Or they can be made with a volt meter live. You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 01, 2010
  • 1,531 Answers
Well i would change the themal fuses that help regulate the temp
there is a kit than can be bought it is LA-1053.includes three fuses
of you can just replace the hi-limt thermostat.
however i would suggest the LA-1053 and replace all at the same time.
there could also be a problem with your temp selector switch that part number is 53-0344.if you replace the switch i would still replace the thermal fuse kit.just to make sure all the parts are the same rating and new together.i hope this helps out.
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Dryer was working fine-washer overflowed-once everything was cleaned up I reconnected it and it fumbles but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Magic Chef CYE4000AWW Electric Dryer
Tumbles, low heat, but not drying clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 13, 2010 | Magic Chef Dryers
Magic Chef electric Dryer won't start
Do you have power going to the receptacle. You can first go to your house panel and look for the circuit breaker for the dryer (usually a 30 amp 2-pole brkr.). It could be tripped. So first, put your dryer in the off position. Next, go back to your circuit breaker in your house panel. Turn off the breaker, and then turn it back on. This should reset the circuit breaker for the dryer. Then go back and try turning on your dryer. If this doesn't work, feel free to contact me again. However, this would seem to be it. Good Luck to you!
Mar 28, 2010 | Magic Chef Dryers
Not Drying, getting heat both it takes about 3 cycles to dry a normal load.
Since Its heating, you should check the outlet hose and vent for obstructions. If that is clear check to see if air is blowing out of the dryer at the hose connection. If no air is blowing out, the fan blades on the dryer may be broken or just clogged up. You may have to remove the back cover and disassemble the lint trap and duct-work inside the dryer to clean thoroughly. You can go to this site www.appliancepartspros.com type in your model number and they will have schematic diagrams to help aid in doing this.
Nov 21, 2009 | Magic Chef Dryers
My magic chef dryer dosen;t always heat up. sometimes drys just fine other times when you put on auto dry it will go for hours and not dry.
it sounds like you will need to change the coils on the gas valve. They are working intermittenly.
Oct 11, 2009 | Magic Chef Dryers
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
My magic chef dryer heats but will not blow air
A dryer fan is usually directly connected to the motor. If you hear the motor running, maybe the fan broke off, or the duct is really clogged.
Jan 11, 2009 | Magic Chef CYE4000AWW Electric Dryer
MICROWAVE WILL ONLY HEAT ON CERTAIN SETTINGS. how do i set the heating instructions?
I have a Magic Chef model MC0160UQ. Within 2-3 minutes of heating food it shuts off completely for about 5min. Also, when I select the low fan it does not work, however the high fan works. Please assist with these issues if possible. Am I able to fix or adjust the magnetron myself since it may be overheating? or what should i do?????
Jul 18, 2008 | Magic Chef CMV1000B Microwave Oven
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
35 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Charles T Nevin
Charles T Nevin
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
