Question about Hotpoint Dryers
My hotpoint ctd00has stopped heating up how do i
My hotpoint ctd00 tumble dryer has stopped heating up how do i fit new thermastats
  • Hotpoint Master
  • 3,463 Answers
You will find the thermostats located at the rear of dryer.
Remove cover, and you will see them adjacent to the heater element, change them both, even if only 1 is faulty.
Please rate my solution.
Thankyou.
Posted on Feb 01, 2010
Testimonial: "great thanks "
After fitting a new time to a hotpoint CDT00
Sometimes even one connection can make the circuit non functionable and so it can be due to a wrong connection. I request that you check once again and logically check the lines to go in order to start the cycle, INLET, cut off from the water level sensor, Start motor, stop and drain, spin and rinse, fill water and then for final dry and drain pump.
Check for all leads to be correct, check if the stepper motor works in circuit to move forward after the main power is switched.
Check this link for tips: washing machine
Jul 02, 2012 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
Dryer revolves but no heat on any settings . hotpoint aquarius tumble dryer CTD00 7Kg.
fixed using posted advice on resetting thermostat.
Many thanks
Dec 10, 2009 | Hotpoint Dryers
Hotpoint tumble dryer CTD00 timer
It is not a difficult job...the thing to keep you out of trouble is to make sure you get the right timer switch, then remove one wire at a time.
Remove one wire from the old timer and put it on the new timer, there is not that many wires for your timer.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 05, 2009 | Hotpoint Dryers
Elements over heating on hotpoint ctd00 condenser dryer
Did you check the fuse in your unit ?
Check the fuse whether it is burned.
Mar 13, 2009 | Hotpoint Dryers
My hotpoint aquarouis ctd00 tumble dryer is heating but no air is blowing through. also there is no water collecting in the water tray
Check all filters and air vents at front and rear of m/c, to make sure they are all clear., do not overload, make sure you have selected right heat setting, and the correct drying time.
It is not usual to feel air blowing out of dryer, because it is a condenser dryer.
Plz rate my solution.
Thanks.
Dec 27, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint CTD00 Door Catch Replacement
If yuo are referring to the catch on the door, then undo all the scews holding the 2 halves of the door together, and prize apart, fit new door catch.
If you mean the door lock, then you will have to remove the top cover and right hand side panel to access the door lock.
Hope this helps.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Dryers
Tumble dryer hotpoint ctd00
Unscrew all screws that hold the 2 halves of the door together, then with a screwdriver or similar, prize apart the 2 halves of the door, be careful the door glass does not fall onto the floor.
Fit new parts, reassemble door, and hey presto!!!
Dec 16, 2008 | Hotpoint NWXR473EV Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Dryers Logo
207 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
