Question about Woods Upright Freezer MU07W
Ice build up at the bottom of freezer (interior_)
    Problem Solver:
  • 7 Answers
Not draining properly
Posted on Feb 03, 2010
Ice in the bottom of the freezer compartment
there should be a drain hole at the bottom of the freezer that goes to a evaporation pan underneath. check to see if the drain is clogged. in areas with high temps and or humidity there will be excessive moisture build up,the more the door is opened the more moisture (condensation). Clear the drain, it may just be blocked by ice, MAKE SURE THE UNIT IS LEVEL! This will let the moisture drain properly and prevent ice build up.
Apr 11, 2014 | Freezers
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
My freezer has ice building up on the bottom
Defrost freezer, and make sure the door close well each time
Mar 07, 2010 | Frigidaire Freezers
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Ice build up
You should to check the Whirlpool Gladiator Freezerator's door sealer to make sure all rubber or plastic seal very well to prevent air humidity come in to build up frost fast. Also, you have to defrost completely and wipe with cloth or paper towel to absorb all waters out and let it dry completely to prevent frost build up.
May 08, 2009 | Whirlpool Freezers
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Woods Upright Freezer MU07W Logo
168 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Woods Freezer Expert? Answer questions, earn points and help others
