Question about Garmin eTrex Venture HC GPS Receiver
Barmin ETrex Hc won't turn on
I tried to update the software for my Garmin ETrex Hc. The data which was on the device was erased and then a window came up saying that the update could not be completed due to dead batteries or loss of power.
The device should have had power from the USB port and it had new batteries.
After this update attempt, the device wil not turn on. In fact it won't do anything. There is a brief flash of white on the screen and then nothing.
Whether it has new batteries, plugged in to the computer, there was still no information on the screen and no indication that the device was on.
Is there a factory reset or reboot that I can try?
Any information would be a great help. Thank You!
  • 3 Answers
I had the same problem as you with the unit switching off.
I found this link http://www.fixya.com/support/t2084694-gps_stay
I held down the joystick button to perform a "Bootlock"
I don't know if it will work for you.
I got Garmins WebUpdater here http://www8.garmin.com/support/download_details.jsp?id=931
Posted on Mar 01, 2010
My garmin 530hcx has locked up on the opening screen...is there a master reset sequence? I have removed the batteries and still won't work! Also, it won't shut off once turned on and locked...
f a device is locking up and has a long noise or beep when powering down, this is due to hidden data being transferred to the microSD data card. These hidden files and folders are being created by the computer and sent to the data card in addition to the maps, waypoints, routes, tracks and pictures that were selected. The following GPS units could experience this issue.
  • eTrex Legend Cx
  • eTrex Legend HCx
  • eTrex Venture Cx
  • eTrex Vista Cx
  • eTrex Vista HCx
  • GPSMAP 60Cx
  • GPSMAP 60CSx
  • GPSMAP 76Cx
  • GPSMAP 76CSx
  • Rino 520HCx
  • Rino 530HCx
To prevent this issue when the device is shutting down delete these extra unused or hidden files and folders from the data card. Examples of these folders are: .Trashes and .Spotlight-V100 folders. Since the Mac OS adds hidden files and folders to mounted removable drive volumes this process cannot be done on a Mac and will need to be done after every time the data card is mounted as a volume on a Mac.
To delete these folders the device will have to be placed into USB Mass Storage mode. To do this:
  1. Connect the device to the computer using the USB cable
  2. Go to the Main Menu
  3. Select Setup
  4. Select Interface
  5. Select USB Mass Storage Mode
The device is now in USB Mass Storage Mode. At this time a window should open on the computer desktop displaying Removable Disk at the top. The Garmin folder will be displayed. Open the Garmin folder.
Do NOT delete the the following files:
  • gmapsupp.img
  • gmapsupp.unl
  • gmapsupp.gma
These files contain supplemental mapping. If delete will cause the mapping to be erased or unviewable.
If there are other folders or files on the data card, delete these. Some of these files or folders may be hidden and therefore will need to be unhidden*. Once you have done so, please disconnect the device from the computer and power it up.
*Note: To Display a file folder that is hidden:
  1. Select the Tools option on the window that appears on the computer when the device is in USB Mass Storage Mode
  2. Select Folder Options
  3. Select View
  4. Open the Files and Folders folder
  5. Open the Hidden Files and Folders folder
  6. Select Show hidden files and folder
  7. Select Apply
  8. Select OK
Once all of the hidden files and folders have been removed from the microSD Card the unit will not
Sep 18, 2011 | Garmin GPS
Webupdater crashed my etrex!!! I did everything they said and it crashed. I need this fixed for my trip up north please help!!!
never use the garmin webupdater, it is unreliable. download the previous version 3.10 firmware from http://www.tramsoft.ch/gps/garmin_etrex-venture-hc-firmware-upgrades_en.html, extract to c:\garmin, plug in your gps via usb, hold the front button in the down position until update process completes, run the updater.exe program and let it complete. You will see an error message at the end of the update process, ignore and let the garmin reboot and it should work again after that.
Jul 30, 2011 | Garmin eTrex Venture HC GPS Receiver
I have a garmin etrex hc and while useing webupdater and downloading new software for it it encounterd an error and now it wont turn on. what can i do?
Best idea i have for that is to try the web updater again and see if it will finish. Otherwise the only suggestion i have is to remove the batteries let it sit for about 10 minutes and then put the batteries back in, BUT AGAIN BUT this may cause problems with the unit since it is looking for an ini file and if the updater didn't do it's job it won't find it and may cause the unit to lock up entirely, resulting in a trip back to the factory for repairs. Hope this helps
May 31, 2010 | Garmin eTrex Euro Handheld GPS Receiver
Garmin Etrex Venture HC will not power up/stay on.
You are not alone it appears. Follow the link below.
Try here.http://www.fixya.com/support/t2084694-gps_stay I had the same problem as you and I followed the advise to do a "bootlock" to download new software via Garmins WebUpdater. http://www8.garmin.com/support/download_details.jsp?id=931
But please note if the unit switches off during update it may cause problems.
Or you could just return to Garmin for a replacement.
Feb 17, 2010 | Garmin eTrex Venture HC GPS Receiver
My Garmin eTrex Summit HC will not turn on. I
absolutely! Hve yoiu checked that this model does not have a switch on the rear as well as on the front? the one of the front is standby. The other one is main power. Not 100% sure about your model so just check first. Other than that take it back to seller for replacement or instructions
Jun 28, 2009 | Garmin eTrex Summit HC GPS Receiver
My GPS won't stay on
I can solve this by not solving it. First I tried reset the unit to default settings: hold down the power, page, and enter buttons at the same time, a message, "do you really wan to reset..." will appear. Select "yes." If the unit reboots, hurrah. If not, call tech support (1.800.800.1020). Get an RMA, send it back to them for repair. I had purchased mine over 30 days ago but less than 60: Amazon wouldn't replace it, Garmin will either replace or repair. If you want them to send a new unit while the old is in transit, just ask; they will charge and then credit a card once they have the old unit is in hand. Good luck.
Apr 25, 2009 | Garmin eTrex Venture HC GPS Receiver
Wont do anything
The eTrex is on the way back to Garmin! I contacted Garmin ref this problem and the tech suggested that I try to 'reset the master'...Power device off (it won't turn on so this was not a problem), press and hold down for 5 seconds the following button combination: page+enter+power. If this works a prompt will come up asking if you want to clear all user data, to which you have to select 'yes' and this will erase all data saved/stored. Leave the device outside for a minimum of 20 minutes so that it may properly acquire satellites. If the device does not awake using these directions...back to Garmin, which is the action I must now take! lt7578
Aug 24, 2008 | Garmin eTrex GPS Receiver
Garmin Vista Shutting down and freezing up
People! The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
May 27, 2008 | Garmin eTrex Vista GPS Receiver
Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
Jan 04, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Venture HC GPS Receiver Logo
580 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
