Question about Toshiba Portege 4010 Notebook
How to Enter BIOS
I need to reset BIOS of my Toshiba Portege 3280CT to autoboot from an CDROM (not SCSI). The CD is active and mounts/umounts well but I can't install a new version of Ubuntu. I did at one time have an answer to this question, but I've lost it. Can you help?
Thanks much
Margaret Wendall
mwendall@gmail.com
Thanks for this suggestion, but I need to enter the BIOS to change the CDROM setting. I found a possible answer at another URL that says to press ESC and then F1 after powering up. It sounds like what I tried before (a long time ago) and I'll post whether this works or not.
And, yes, I do have a backup of all my data, but I bought the laptop used and it didn't come with any Toshiba disks or CDs.
cleopanther
Posted on Feb 19, 2008
    Genius:
  • 3,587 Answers
Setup is always F2 on startup..that should get you there, methinks.
got backup for that Toshiba?
Is it possible to access the whole C drive when using Ubuntu?
What Can Be Mounted
The most common thing to be mounted is a hard drive partition. Hard drives are kept in /dev and have different names depending on what type of drive they are. IDE/ATA drives are labelled as /dev/hda, /dev/hdb, /dev/hdc and /dev/hdd (since a PC's IDE interfaces can only handle 4 devices at a time). Note that these can be devices such as IDE/ATA CDROMS, Compact Flash to IDE converters, and some special floppy drives (although they tend to appear mainly in laptops). For SCSI devices the labels are /dev/sda, /dev/sdb, /dev/sdc, /dev/sdd, /dev/sde, /dev/sdf, /dev/sdg, /dev/sdh and /dev/sdi (since a SCSI chain can contain up to nine devices). Other types of drive, such as USB, SATA, etc. are mapped to these SCSI devices by Linux. Therefore SATA and USB drives are labelled as /dev/sdX where X is a letter, starting at "a".
Since these are literally the devices you can issue a command such as:
sudo eject /dev/hdc
If /dev/hdc is a CD drive then it will eject.
In the case of hard drives, there is another abstraction. A hard drive (and many devices such as USB "sticks" which act like hard drives) can be partitioned to allow many filesystems to be stored on them. This means that the filesystems themselves are accessible via the partition labels, such as /dev/hda1 (the first partition on /dev/hda). This means that we finally know about something we can mount, a partition, since it contains a filesystem.
Another physical filesystem which can be mounted is the ISO9660 filesystem used on CDROMs. Since there is only ever one CD in a CD drive there is no point creating /dev/hdc1 (where /dev/hdc is a CDROM drive) since there is only one filesystem on it. That means that you can mount CD drive devices explicitly, so if /dev/hdc is a CDROM drive then it is possible to mount /dev/hdc if there is a disc in it.
Floppy disks only contain one filesystem, and are labeled as /dev/fd0 for the first drive, /dev/fd1 for the second drive, etc. So now we know three things which can be mounted.
Devices like USB sticks are treated like hard drives (so /dev/sda1, for example, may contain a filesystem) and so are iPods (although I think the main data on an iPod is stored on the second partition)
Mounting is not restricted to physical devices. If you have a filesystem "image" (which IS a filesystem, whether an exact copy of an existing filesystem, or a filesystem created specifically for that file) then you can mount that through the use of a fake device called the "loopback device"
How To Mount/Unmount Filesystems
Unmounting
Firstly I will tell you how to unmount any filesystem you mount after trying these commands. Unmounting is done through the "umount" command, which can be given a device or a mount point so:
sudo umount /mnt
sudo umount /dev/hda1
Would both unmount the filesystem on /dev/hda1 if it is mounted on /mnt.
Remember that a filesystem cannot be in use when it is unmounted, otherwise umount will give an error. If you know it is safe to unmount a filesystem you can use:
sudo umount -l /mountpoint
Sep 23, 2011 | Microsoft Computers & Internet
I need a user/operaing manual for a Pioneer PD F19 CD Player
yes
What Can Be Mounted
sudo eject /dev/hdc
Unmounting
sudo umount /mnt
Sep 23, 2011 | Cameras
Hi I have a problem trying to install win xp on a toshiba portege 7100 series but it wont boot from the cd. I now that my cd's ok so thats not the problem, do I need some kind of a driver for the...
when you boot the machine, check for a boot options option to tell the machine to boot from the cd/dvd drive, alternatively go into the bios settings and there will be an option in there to set which device to boot from.
May 05, 2011 | Toshiba Portege 7100 Notebook
How do i get my toshiba portege m 100 to boot from cd
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps good luck
Sep 13, 2010 | Toshiba Portege M100 Notebook
How can i enter the bios environment on toshiba portege 3500 tablet pc
hold the "esc" key presed during boot, and then pres the "f1" key and you enter to the bios
May 20, 2010 | Toshiba Portege 3500 Tablet PC
I cant get into the BIOS from Portege 3500
Keep hitting escape while starting up. Message will say there is an error and hit F1. Hit F1 and you'll enter bios.
Apr 18, 2010 | Toshiba Portege 3505 Tablet PC
How can i enter to the biois menu???
when computer boots, press F2. You can also press F10? or F12? to access other menu. You should set cd rom as first bootup device. Otherwise search command prompt in search menu on start menu
Jul 13, 2009 | Toshiba Portege M700-S7044X Notebook
Portege 3505
pls get ur cdrom service & try again but prior to that pls check ur data cable which is connected to ur pc
Jan 12, 2009 | Toshiba Portege 3505 Tablet PC
My Cd-Rom/DVD-rom don't work. It doesn't open any folder. I thought I have problems with drivers: SCSIVAX DVD/CD-ROM SCSI CdrOM DEVICE DVD-ROM SD-R2102 TOSHIBA LAPTOP SATELLITE 5005-S507 THANKS, OSCAR
According to the Toshiba website, the scsi cd-rom/dvd-rom does not require a driver to operate, but the driver for the scsi controller card it plugs into may need to be reinstalled or updated. Visit the following link, and go to the section labeled scsi cdrom/dvdrom. At the bottom of this section there are two links to websites where you may be able to find the drivers for your scsi controller card.
http://sdd.toshiba.com/main.aspx?Path=8100000000220000000100006598000000E7/810000000C58000000010000659C00002C36
Apr 09, 2008 | Computers & Internet
BIOS
hit the esc key
Dec 16, 2007 | Toshiba Portege 4000 Notebook
Toshiba Portege 4010 Notebook Logo
251 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
