Question about Pentax K10D Digital Camera
I Inserted new Battery,after five - ten minutes, the camera shows that the Battery should be changed.And i cant turn the camera on. I checked batteries an they were full. What should i do? Pentax 10d
  • 2,517 Answers
Go in setting option and select your battery type from there. After that restart you camera if you face the same problem then visit service center. THe power transfer IC may be not so powerfull , need to change.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Posted on Feb 01, 2010
How do I reset my computer on 2011 dodge ram
dissconect battery for a few min if that dont do it contact your local ten min oil change they will know how to do it
Mar 20, 2015 | 2011 Dodge Ram 1500
Changed battery and replaced lost key. Now it won't start
nitabelle57, It sounds like your security system will not recognize the new key you purchased. Keys have a chip in them which has to be recognized by the security system in order to work. The new key has to be programmed by your security system before it will start your vehicle. You will need a battery charger to program the key as this procedure takes thirty minutes to do. Put the charger on the battery. Be sure everything else is turned off. Place the new key in the ignition and turn it to the run position. The security light should come on. After ten minutes the security light should be out, if not proceed anyway. Turn the key to the off position but do not remove it. Wait five seconds and turn it to the run position once again. Wait another ten minutes and turn it off again. Wait five seconds and turn it to the run position once again. After the final ten minutes turn the key off (do not remove it) Wait thirty seconds and then the key should be programmed. If you have any other keys they will not work now as the security system is now programmed for the one key. If you have another key and need it for another driver then start the vehicle with the newly programmed key and let it run for about a minute. Place the extra key in the ignition and turn it to the run position and wait sixty seconds. This should solve that problem. Good luck with this.
Aug 10, 2011 | 1997 Pontiac Grand Prix
Wife used cig lighter adapter last night to blow up air mattress this morning new battery less than 1 month old wont start car. charged battery now when i turn the ignition key to start car the car alarm...
turn the igntion on, don't start, let it set for ten minutes Turn it off for 5 seconds then try to start it. If it lost memory for some reason and doesn't start . then do this three times , after the third time start it. that is the relearn procedure. Have a charger on it for the 30 minute relearn. Relearn is on for ten m off five s on ten off five on ten off five then start
Jul 02, 2011 | Chevrolet Lumina Cars & Trucks
Security light keeps blinking in my five hundred and the car will not turn over. It cranked fine an hr ago, but now nothing
Try and disconnect the battery for ten minutes. During that ten minutes, take some sand paper, and scrub down every terminal metal surface on that battery and the cables to bright and shiny. Then, rehook the battery. Put the key in the ignition, and let it set for 20 minutes. I think that will get it going again.
Jun 27, 2011 | 2005 Ford Five Hundred
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
My 1999 Tahoe cranks up but will not stay running. Seems like fuel pump, filter, or injectors. Any suggestions?
check theft system for problems with program(dealer)..disconnect battery for about five minutes,reconnect and try to start,if starts and then stalls leave key on for ten minutes exactly...then turn key to off position for 15 seconds..then start...if starts allow to run for ten minutes..
Dec 27, 2009 | 1999 Chevrolet Tahoe
96 s10 2.2 4cyl. running lean . It has new fuel pump and fuel filter. I've checked the converter, new 195 degree thermostat,changed fuel regulator,changed front 02 sensor, changed coils and Diagnostic tool...
I know you said new fuel pump and filter but I would recheck the fuel pressure. Drive the vehicle with the fuel pressure gauge on it and see if the pressure drops after 10 minutes.
Sep 02, 2009 | 1983 Chevrolet S-10
Turned power off in house alarm went off. keypad now showing 77 and alarm wont reset
pull transformer out of outlet---disconnect battery---let it stay down for five or ten minutes--make sure you have a known-good battery --ready--re plug transformer,then battery,if it comes up armed,put your code in
Apr 14, 2009 | Home Security
Phone regularly cutting out
This is due to malfunction of battery,
i have also experienced same kind of problem with nokia set which is other model. i have also done same what you have done. Change or replace your mobile battery. so it 'll finally solves your problem.
Apr 21, 2008 | Nokia 2310 Cellular Phone
Pentax K10D Digital Camera Logo
52 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
