Question about MSI 845GLMS-L (MS-6754G-020) Motherboard
Cannot fix partion error
For some reason my machine powers off without notice, only during win xp boot from cd, or if i use a hd that already works it errors, then powers off after a minute.
i've triedeverything help
    Master:
  • 474 Answers
It sounds like its overheating or has bad hardware on the mainboard.
Look at the Capacitors ( the cylinderers with flat tops sticking up from the board) They should have flat tops, if there domed or have crud on top, then they have gone bad and the system will eventually quit altogether. get a new mobo. If you say that the Hard drive is proven good, then its the mainboard.
Posted on Feb 19, 2008
I have a dell E510, trying to do a fresh install of windows 7, but it wont boot from cd, or usb flash drive. boot order was changed to boot from cd first then usb second. after that failed hit f12 and...
Hello
If this is a win 7 upgrade you need to have xp installed first,then you can install win 7.
If not,then in the boot order change to cd dvd then hdd,if you have two hdd make sure your primary is first.
Last,if you have a xp disc boot from that and do a delete partion and format the hdd.Then try win 7
Apr 04, 2011 | Dell Dimension E510 PC Desktop
Task manager in win xp keeps blinking, it will not closed, no matter what i push nothing, plus win xp keep freezing any solution how to fix this problem
VIrus infection?
to check and secure u need:
win-xp cd or other bootable win-cd, seperate up-to-date antivir software on cd or usb-stick,
your passwords
procedures:
boot system from cd/dvd (do not bother if screen resolution is different from usually),
exit windows-setup,
insert antivir-cd or stick, run full system scan.
found infections? remove/erase these files(antivir will do that for you)
if possible, back-up personal data (my folder, music, save games, etc.)
this data has to virchecked by another protected system before reinstallation !
boot from win-xp cd-rom, run setup until repair options are available,
repair your xp on harddisk(xp-will do that mostly), exit setup without installing win xp anew
boot system from hd, ignore error messages, run vircheck again.
if you're lucky, this will do, else lemmie know
Jun 13, 2009 | Dell Inspiron 6000 Notebook
No internal hard disk found during booting when i am going to format
It is possible that the HD has failed completely. However, this is a relatively new laptop, so I would suspect that is not the case. Sometimes the HD will lose contact for one reason or another. This can usually be cured by removing the HD and reinstalling it, which will remove any crud from the contacts.
http://www.fixya.com/support/t1639067-reseat_hard_drive
If the machine is still under warranty, call Dell support. They will walk you through diagnostics to determine the actual problem.
If you're not sure of the warranty status, go here:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen
HTH
May 24, 2009 | Dell Inspiron 1525 Notebook
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Oct 17, 2008 | ASUS A7S8X-MX Motherboard
PC keeps on restarting
Power supply can be your issue , when windows boots from CD it a mear dos-mode boot , If it was motherbaord problem it wouldn't boot at all . If you move power supply to test the motherboard issue just make sure it enough power to boot the other motherboard ( some pwer supplies can boot all motherboards )
Jul 31, 2008 | ASUS P5S800-VM Motherboard
Help me to install WinXP in a Gateway Laptop that came with SATA HDD
you have probably already fixed this but maybe others can find this a little helpful. i had to downgrade a gateway ma7 for one of my customers who had lost their recovery cd with vista on it. Their HD had gone bad.
The reason the XP installer says "no HD" is because the the drivers required by the gateways Sata controller (hd controller) are not preloaded on the xp install disc. The only way around this is to download the windows xp compatible sata drivers from gateways website and then slipstream them into a custon windows xp install cd. its actually not as difficult as it sounds. just download the sata driver, a slipstreaming program called nlite.
1 download and install nlite
2 put in your xp install cd, and run nlite, when nlite asks, browse to the i386 folder (your installation files)
3 you will have lots of options to choose from, but for this purpose, choose "add drivers" and select the location of the gateway drivers (c:\cabs\something) i think.
4 finish and burn the cd. then use it to install windows xp.
this little guide isnt step by step, but with a little trial and error you should get by
-Nele, MCSE
Jul 19, 2008 | Computers & Internet
NTLDR missing
Without a windows xp cd you are left with only 1 option. If you have a different machine which is connected to Internet or has windows xp installed, you can download the boot files from the net or copy the boot files located on the root of C drive (ntldr, boot.ini) onto a pen / floppy drive. then change the boot order in the bios to boot from the pen drive. It should work if you have the similar partioning scheme of the source computer. If booting is successful, u can copy those boot files to your computer's C drive.
Let me know what happens.
Apr 15, 2008 | HP Pavilion dv6000z Notebook
When I turn on starts shows microsoft windows then goess to startup repairs
formattt that hard drive sound like bad secters in hd run xp dish cheak chdisk u know to fix those bad secters on hd froma bug or sumthign best best u have orginal xp cd not recovery dish operting system disk boot into that del partions make new one then formatt it then install xp fresh update it so on ok
Jan 24, 2008 | Computers & Internet
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Win xpp
Its quite easy to repai windows xp. First make sure that your first boot device is CD-ROM. Insert the winxp cd in the cdrom and restart the computer. Now it will ask you to press any key to boot from cd,  you press any key and it will boot from the cdrom. Now follow the instructions and windows will show you all the partions then it also shows you that you have windows already installed and to repair it press R. Then you choose the partition in which it is installed using the arrow keys and press R key through the key it will repair the windows xp.
Oct 24, 2007 | Microsoft Windows XP Professional for PC
MSI 845GLMS-L (MS-6754G-020) Motherboard Logo
41 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
