Question about HP PSC 1410 All-In-One InkJet Printer
When Printing labels the printer starts to soon and bottom lables are cut in half?
    President:
  • 2,306 Answers
After you press print the window pops up with printing preferences, select preferences and tell the printer you are printing labels, it will allow more time for the label to reach the start position and start at the right place on the label sheet.
Posted on Feb 01, 2010
How do you format lables to print properly on the richo e7000?
Printing labels is a pain! It is much easier to print using an A4 sheet with (say) 7 rows of 4 labels on.
I suggest you use the Ricoh support site
http://www.ricoh-support.com/Enduser/support/
May 07, 2014 | Office Equipment & Supplies
Label printing
you'll need new drivers for vista...get them here
Mar 20, 2008 | HP Officejet 5610 All-In-One InkJet...
When printing from a Zebra TLP 2844, text is getting cut off. I am printing from internet software, center aligned. If there are too many characters, the text is getting cutoff on either side (I would say...
Check the drivers you are using, try downloading drivers from Nice Label or Segull Scientific. Setup the page size to fit all the text, use a ruler to measure the lables.
Apr 27, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My printer appears to be printing the lables but
Make sure you are using thermal paper roll and not regular label roll.
Oct 05, 2009 | Zebra TLP 2824 Thermal Label Printer
How do you center the word in the center of the label? Meaning if a lable is 4 inches long and the word is 2 inches long I want an inch on both sides.
It's not a hi tech printer, to get close to that you need to space before printing and after, and use scissors to cut for an even label.
Oct 02, 2009 | Brother PT-1000 Thermal Label Printer
My dymo starting printing only the bottom half of my labels, do i just need a new ink cartridge or is this a different problem? the bottom half seems just fine...
Take out tape cartridge, make sure tape is going THROUGH both top and bottom tape guides. Clear all.
This should work. You also may have set up for second line printing. Go through all settings and clear.
May 06, 2009 | Dymo LetraTAG Thermal Label Printer
Prints half of label
Restart your computer. Turn your printer off and back on again. Restart your software for printing lables. When updating the printer drivers, all software needs to be restarted to make sure that the form controls are working properly.
Oct 06, 2008 | Zebra Eltron LP 2824 Thermal Printer
Label printing
If you don't change your settings this is the problem of your printer hardware. Just open the printer & you can see a long rod & some devices fitted in the both end of the printing area it called carrage Assembly. there you can see two small clip it is the device of mergine settings change it as you like. If it won't work for a single time try to do this in many combination.
Feb 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Reg. zebra S600 lable
I had this happen when I changed from one label to a different size label. It needs to be calibrated. There are several types of calibration to do to the S600. Here is the solution that worked for me.
  1. Check the position of the laser Media Sensor (figure 13). It may need to be moved to match the type of label that will be printed.
For CARD labels, the media sensor needs to be set at the edge of the card so it can “see through” the notch that is cut on the edge where the perforation is.
    1. For STICKY labels, it can “see through” the backing which shows between each sticky label, so the Media Sensor could be set anywhere for it to work, but will probably be set towards the middle.
Set to Factory Defaults. This is so that all of the following steps will work. I do not need to change the steps based on the type of mode that printer is set up in because it will erase all that by setting it to the factory default. (See figure 14 for buttons)
    1. Turn off the printer.
    2. Hold the FEED and PAUSE buttons down as the printer power is turned on.
    3. Press MODE button four times.
    4. When the defaults are saved to the printer, the CALIBRATE, DARKER, and POSITION lights will all flash.
Test to see if the calibration is set correctly for the label. If not, proceed to the following steps.
  1. Do a Manual Calibration.
    1. Hold the PAUSE, FEED, and CANCEL buttons down as the printer power is turned on, keeping the buttons depressed.
    2. This will run through several labels and do some printing.
    3. Release all three buttons after the CALIBRATION light comes on and then goes back off.
Put the printer into Auto-Calibration Mode.
    2. Hold PAUSE, CANCEL, and MODE down as the printer power is turned on.
    3. Release the buttons after printer is powered on.
Dec 14, 2007 | Zebra Stripe S600 Thermal Label Printer
Zebra S4M Thermal Lable Printer Not Printing Correctly.
Is the Media guide st corectly?
This link is for a datamax but all label printers are stuctured the same way.
check
http://www.posguys.com/download/88230401_a.pdf
Oct 26, 2007 | Zebra S4M Thermal Label Printer
HP PSC 1410 All-In-One InkJet Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
