Question about Motorola Mobility RAZR V3
Blank screen my razr screen is blank. on the outside & inside.i can turn it on, make calls, recieve calls, everything.but i cannot see. i read that i should hold * and #,but this does nothing. i also read that if that doesn't work then it must be the flex cables. if that is the problem, can this be fixed? and how? My razr is retarded. The screen is all white and blank, but the phone itself still works but you just can't see anything. I read that if you turn it on its side and bang on it that the screen will turn back on...I did that but all it does is it tries to load the screen and it gets all these thick red lines across it, and then it goes blank again. Any help?
  • meeps Mar 31, 2008
    My screen died after going through airport security. The volume is really low and cannot be increased. I can use speaker phone only. I cannot figure out how to store anything to the sim card as the screen is completely dead:( Where can I get the lcd screen replaced and what is the associated cost? Help me somebody!
  • Anonymous Mar 31, 2008
    Razor screen is blank. I'm assuming it's the ribbon cable.
    Inside and outside screens illuminate but, there are no characters.
    How do you get to the cables to make sure they're plugged in properly ?
Tighten the 2 torx T6 screws under the battery cover. This solves it in a lot of cases.
Posted on Mar 24, 2008
    Brigadier General:
  • 7,752 Answers
Have the LCD replaced and that will correct the problem that you are having.
Posted on Feb 21, 2008
Screen went blank
Screen web broken. Take to a shop. Won't be cheap. If you find this helpful, please post as such.TY
Jan 17, 2009 | Motorola Mobility RAZR V3
Blank screen
pull the battery from it for a little while , if that don't do it its probably a display chip inside and it can't be replaced , they have been having problems with the screens on these phones , does the phone still work for recieving and sending calls? its not likely but not impossible the screen went
Oct 10, 2008 | LG Shine KE970 Cellular Phone
Blank screen
this happens either when u r razr was dropped or have gotten wet...If it fell u need to remove the four screws on the screen and pry the cover off with a possibly thin knife.The flex cable is located at the top left hand side of the screen. you need to take this off and reseat it again.try powering on the phone before u close it back again to ensure that it works.If this doesn't work either your screen or flex cable is gone, then u need to check a phone repair shop.you need either a t6 or a t4 screw driver set to remove the four screws located under the the 4 rubber fillers on the inner screen.
sam !
Feb 19, 2008 | Motorola Mobility RAZR V3
Inside and outside screens are blank..
My V3 doesn't work either, the screen randomly turns on occasionally but try taking out the batery and the sim card and they inserting it back in. If this doesn't work i suggest taking the phone back to the place where you brought it. Hope this helps!
Dec 11, 2007 | Motorola Mobility RAZR V3
Access To Recieved Calls
u go to call log settings and check whether save call log option is turned on
Dec 04, 2007 | Motorola Mobility RAZR V3
Razor screen went blank
i tried some electrical contact cleaner (brake cleaner WAL-MART .89 cents) on the hinges. Open ti back and forth several times. NOTE: do not spray alot, just a little at a time. Then it got squeaky and started working. Then I sprayed a little WD-40 on the hinges and it works fine.
Nov 16, 2007 | Motorola Mobility RAZR V3
Blank screen
Seriously, bang the phone sideways on a desk, it works! Do it on each side 2 or 3 times, then back again. Don't slam it down, but bang it a couple times I'm not kidding at all
Nov 12, 2007 | Motorola Mobility RAZR V3
Motorola razr v3 (black) screen has white blank
Well i suggest that you take the case of your phone and have a look at your screen maybe some of the screws have gone missing or the screen has just worn itself out? . Note youll need a t6 or t7 torx screwdriver to do this , hope i helped
Oct 17, 2007 | Motorola Mobility RAZR V3
Blank screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Aug 27, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3 Logo
129 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
