Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell Pro Heat bladder is moldy. Water was left in it. Mold will not scrub off- is there some type of special cleaner for this?
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
696o
Posted on Sep 30, 2010
My bissell pro heat pet steam cleaner has mildew in the water bladder. How can I clean that?
a mixture of --napisan or bleach and cold water will kill the growth
only use cold water and rinse thoroughly after treatment
read the user manual first to make sure that bleach is acceptable to use as it may affect the bladder material
Nov 29, 2016 | Bissell Vacuums
Bissell pro heat wont spray water
Hi, it's Allie from Crucial Vacuum!
Your Bissell ProHeat 25A3 may have stopped spraying water for several reasons. Make sure the bladder or water tank of your unit is filled with water properly and that the 2-in-1 tank has been placed properly.
If the water tank/bladder is filled and the 2-in-1 tank is placed properly, your unit's pump may have lost prime, to check this turn your unit's power off and hold spray trigger for 30 seconds. Turn the machine back on and check the spray flow.
Another thing that may not be allowing your unit to spray properly or spray at all is having a clogged solution filter and may need to be cleaned.
Last, your unit's pump belt may be broken. To replace, turn off your unit and unplug from any electrical outlet. Use a flat head screwdriver into the slot of the belt access door to release where you should have access to your unit's pump belt.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
We have a bissell pro heat and the soap dispensor puts out way to much too fast. It fills the bladder with bubbles in seconds. How do we fix?
There is a setting on the unit, near the floor. You can set it to spray HI, LO or ONLY Water. You can set it accordingly between settings too.
Hope this info was helpful to you. Good Luck!
Jan 31, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I have a billell Pro Heat 2X without a manual. How do I fill it and what ratio water to cleaner?
The cleaner goes into the small bottom at the very rear of the machine. It is uses full strenght (don't add any water to it). You add clean water into the bottom clear plastic section on the front of the machine. The clean water bladder is soft plastic and it is filled from the top. When you start using the machine, the dirty water will get suctioned into the section surrounding this bladder. The machine will stop working when either the bladder is empty or the dirty water section is full. Remove the entire plastic section to dump out the dirty water.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Does the cleaner solution go in small tank. Should the little tube be down in solution?
http://www.bissell.com/Product_Search.aspx?Criteria=1699
Above is a link to bissell.com where you can get the full user manual. But to answer your questions, the cleaning solution does go into the small tank with the tube, the tube should be arched and go to the bottom corner of the small tank. Clean hot (not boiling) tap water goes into the inner bladder of the big tank. Fill it till you can see the water near the top.
Oct 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
98 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
