Question about Logitech X-230 Computer Speakers
X-230 Xbox 360/Computer Problem.
I have my xbox 360 hooked up with a left/right audio to auxiliary adapter cable with a female end, and the inside of my soundcard is a female input. I have a splitter that has the male end of the X-230's cable plugged into it, and two male ends one that goes to the xbox 360's female end, and the other male end plugs directly into my sound card.
Problem 1 - When the Xbox 360 is turned off, a crackling occurs on the satellites while listening to anything on the pc. When the Xbox 360 is turned on, the PC's sound is back to normal.
Problem 2 - My Xbox 360 sounds like it is at half the normal volume it would be if it were just plugged in by itself with no splitter.
Anyway to fix both of these to have full volume on both, maybe a audio switch that will work?
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Frist Things first!
1) CHange the input cables for Spks, for another with cooper or gold conductivity.
2) clean ends for dust on inputs.
3) try to reconnect the speakers carefully and test sound.
you can figure out when some sound are bad in any connection on this way.
Good Luck
Posted on Feb 25, 2008
XBOX 360
How to Connect XBOX 360
This is the back of the Xbox 360. The ports for the power cable, A/V cable, and ethernet cable are pretty easy to find. When you set up your Xbox 360, make sure it is in a well ventilated area that is free of dust. Dust and overheating are the two main causes of problems in electronics so choosing the right placement for your Xbox 360 is important.
This is the standard Xbox 360 A/V cable that comes with the premium version of the Xbox 360. The wide silver end connects to your Xbox 360 while the other end connects to your TV. The Yellow (video) cable is for standard, non-HDTV sets. You will also use the Red+White audio cables for a standard set. If you have a newer TV or an HDTV set, you can use the Red+Green+Blue video connections along with the Red+White audio connections.
This shot shows what the back of most TVs look like. If you have a standard TV, you'll only have the Yellow+Red+White connections. If you have a newer TV or HDTV, you should have the same connections that are shown in the pic. This step isn't too hard since the cables from the Xbox 360 and ports on the back of your TV are all color-coded.
If, and only if, you have an HDTV and want to use your Xbox 360 in 480p, 720p, or 1080i resolutions you have to slide a little switch over on your A/V cable. On the end of the A/V cable that connects to the Xbox 360, there is a little switch that you'll need to click over. If you do not have an HDTV, you can skip this step.
Now that you have the audio/video cables connected, the next step is to hook up the power supply. Connect the two parts as shown in the picture and then connect the "power brick" end to your Xbox 360 and the other end to a wall outlet. The big power brick needs plenty of ventilation just like the main system so try to have an open space on a shelf for it. It is not recommended that you set it on the carpet.
Once you have everything hooked up, you are ready to go. Press the large circular power button to get things started. If you have a wired controller, plug it into a USB port behind the little USB door. If you have a wireless controller, hold the silver "X" button in the middle of the controller until the upper left quadrant of the system power button as well as the ring around the "X" button on the controller light up. If it doesn't light up, press the controller connect button on the Xbox 360 as well as the connect button on the top of the controller.
If this is the first time the system has been used, you'll have to go through an onscreen setup process. This is simply setting up your player profile, choosing HDTV settings if available, and/or signing up for Xbox Live service. The system walks you through everything.
Now you are ready to play.
Sep 06, 2008 | Microsoft Xbox 360 Console
What cables do I need to plug my X Rocker Chair model #51231 into my Xbox 360?
You need to go buy another cable, get a good length RCA Audio Red White Cable 2 Male To 2 Male one that suits the distance between the chair and the xbox.
Then you need to get a Hosa GRA101 RCA Female to RCA Female Coupler Connect the adapter to the ends of the red and white audio cables on xbox, connect your new rca cable to the adapters, connect the cable to your pyramat seat. Connect xbox tv cable to tv as normal.
May 31, 2012 | Pyramat Sound Rocker Gaming Chair
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
How do I make my dlink dwa-130c wireless adapter work with xbox 360 for xbox live
Bridge the Connections. In other words, plug in the internet cable into the xbox, and the other end into your desktop or laptop. After this is done, select both the wireless and the local connections (go to your network connections) and right click on the "Wireless Network Connection" icon. Hit "Bridge Connections" and it should work. REMEMBER that the Xbox WIFI will turn off if the computer does.
Dec 27, 2009 | Microsoft Wireless Network Adapter Xbox...
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
Pyramat 450 wireless sound rocker. Comes with white/yellow/red rca jacks, how would I install that to a xbox 360? The xbox will play through chair if I connect xbox input jacks to chair! But you then get...
You need to go buy another cable, get a good length red and white rca cable one that suits the distance between the chair and the xbox.
Then you need to get a female to female rca adapter. Connect the adapter to the ends of the red and white audio cables on xbox, connect your new rca cable to the adapters, connect the cable to your pyramat seat. Connect xbox tv cable to tv as normal.
Jul 11, 2009 | Pyramat PM450WR for PlayStation 2,...
Ip addresses
the wireless adapter is when you have a wireless router,take off the adapter and plug the ethernet cord from the modem to your xbox
Jul 13, 2008 | Microsoft Xbox 360 Console
Connections
What the two do is give the audio, you need a 'Y' phono (2 female to male connector adapter) and a female- female adapter to suit your speaker connector and the male end on the adapter so that you can plug in your two cables and the plug in the outlet your pc speakers plug, it will cost about £5 or $10 wherever you are. I have done it and its worth it for the picture quality. see below http://www.maplin.co.uk/Search.aspx?criteria=phono%20adaptors&source=15&SD=Y
Oct 05, 2007 | Microsoft Xbox 360 Console
Logitech X-230 Computer Speakers Logo
279 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
