Question about Samsung SyncMaster 403T 40 in. LCD Television
How do you connect the aerial to the back of the Samsung Syncmast
How do you connect the aerial to the back of the tv. It only has a printer type port in the RGB port
    Problem Solver:
  • 6 Answers
This is a monitor, not a TV.
Therefore there's no tuner, no antenna input.
Posted on Feb 15, 2010
Panasonic User Manual
as far as I am aware, you need a standard analogue aerial to receive Freeview, not a dish. The aerial plugs into set top box, which is connected to tv by scart. Freeview is different from Freesat
Nov 08, 2013 | Lands Phones
The aerial port does not work.
It is possible the tuner or antenna connection is bad---If you can call up the menu with the remote set needs to be switched from cable etc to air or antenna and channels programed------not on the rear input connection but for the tuner in the set (presume it has a tuner if antenna connection of any type is there.
Oct 29, 2012 | Televison & Video
Hi about a month ago my samsung 42" stopped showing free view it just says no signal have checked everything i still have a signal on the tvs up stairs off the same aerial
The first thing you should do, is connect the Samsung TV to one of the working aerial inputs upstairs, and then run the auto-setup / digital channel scan. If it works, it's most likely a localised problem with the aerial cable - or you accidentally selected a different external input.
Try this simple test first and then post back with the results. I will then try to assist you further.
Oct 19, 2010 | Samsung LE40R74BDX 40 in. LCD Television
How to hook antenna to tv?
optimum reception of colour requires a good signal and will generally mean that an outdoor aerial must be used. the exact type and positioning of the aerial will depend upon your particular area your dealer or service personnel can best advise you on which aerial to use in your area. before connecting the aerial cable,turn off all main power switches. vhf or uhf it must first go to the media box and you will see the input aerial cable connect it there and the output go to the back of your tv that indicates aerial input terminal.
Oct 15, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Cant retune to pick up dvb samsung le 26r74bd
Hi return the TV with out the aerial connected and wait until it finishes then plug the aerial back in and try again. Let me know how you get on.
Apr 22, 2010 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Tv & video: Which cables join to where
You need to put the main aerial into the vcr,then a male to female fly lead from the vcr into the tv and then a scart lead from av1 on the vcr into the scart socket on your tv.
Sep 13, 2009 | Televison & Video
I'm not sure where to plug into the tv the aerial lead
the end of the antenna wire will screw on a threaded antenna connection on the back of the tv
looks like this type of connection
Mar 21, 2009 | Sanyo DP32746 32 in. LCD Television
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Samsung SyncMaster 403T 40 in. LCD Television Logo
157 people viewed this question
Henry  Thomas
Henry Thomas
