Question about Whirlpool GGW9200L Gas Dryer
Gas burner will not fire up it stays on sensing mode only .
It will run the whole cycle without heat
  • cruzer1001 Feb 01, 2010
    dryer would run ,stays on sensing mode for the whole cycle without firing on
    the gas burner.
    Scholar:
  • 91 Answers
blocked exhaust vent
bad thermal fuse
post some feed back, thanks!
Posted on Feb 01, 2010
When I turn it on to the heat cycle the fan does not run, I have swapped the control board with another unit that was working and still get the same result the unit runs on all other cycles.
This is not true if your system is a heat pump. When the thermostat calls for heat, and the burner ignites the gas, a thermal sensor switch senses when the hot box has heated and then the sensor turns the fan on, this is so no cold air is blown into the ducts and living space. Also, another sensor senses the heat box if it gets too hot, cuts out the burner, if this sensor is not working then the burner will never light. Two sensors that may be keeping the heat from working among other possible causes, one step at a time in trouble shooting. Does the burner turn on at all?
Apr 25, 2015 | Heating & Cooling
Tip
Cruise Control for Your Oil Burner to Save Money
The Beckett HeatManger is a microprocessor controlled device that will manage the on/off cycles of your boiler. Every time your boiler has to shut down and then restart your have just lost a bit of efficiency. By reducing the start/stop cycles of your boiler you not only reduce fuel consumption, but you also reduce wear on the parts of the boiler and emissions coming from your boiler. Your burner burns very inefficiently on startup and shut down. When I have my combustion analyzer on a burner it goes crazy with bad gasses right after shutdown.
If you have a fuel oil or gas fired boiler and you are wondering how you can save money on your heating bill without replacing your boiler then I have good news for you! By adding a simple device to the burner of your boiler you can be saving at least 10% in minutes
With this control if your thermostat requests heat and the HeatManager has sensed that there is heat available in the boiler, it will not start the burner until the heat is used up. When the burner is running, the HeatManger will optimize the runtime to match the boiler output to the load.
The unit is very easy to install. It is mounted to the junction box under the relay and wired into the normal burner relay wiring. There are a couple of sensors that need to be attached. One senses the supply water temperature for heating, coming out of the boiler and the other senses domestic hot water boiler supply temperature.
Even if you would decide to get a professional to install this unit you will be on the road to saving big dollars while only spending few hundred bucks. Then when the price of fuel oil and natural gas begins to rise again, which it will this winter, you will be getting even more savings from your small investment.
Saving money is always a good thing, but when you can combine saving money with greater comfort than I would call that a great thing!
on Dec 17, 2009 | Heating & Cooling
My gas dryer the heat cycles on & off
clothes not drying, but dryer runs & heats?
1.defective thermostat-----replace
2.fan or it's pully loose on shaft----tighten set screw
3.incorrect heat or timer setting---reset timer
4.clothes to wet to when placed in machine
5.clogged lint screen or duct---clean out
Jul 29, 2010 | Roper RGS7646KQ Gas Dryer
Have to light the pilot every morning, then furnace fires up but fan short cycles for about 4 minutes then goes off and comes back on.When the fan goes off the burners stay on. Will do this for a while....
hi clean the air filter , then clean the the afc sense at the bask of it , try this sounda as it is over heating and shutting of on the fan over heat
Feb 17, 2010 | Heating & Cooling
Duet/whirlpool model GGW9200LQ0 dryer will start but will not fire up the gas burner. it will stay on sensing mode. will run the whole cycle without heat
It appears your gas valve, thermocouple, or gas valve solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a technical question regarding implementation of my Carrier furnace within my residence. Specifically, the furnance has been installed for 17 years and I have not had any problems with it. I have...
Thats a safety.
The unit senses a failure to ignite, so it goes into safety mode keeping the blower running to prevent overheating and fires. And keeping the inducer motor running to prevent the same, as well as raw gas build up inside the unit.
The newer systems are "smarter" and can detect more specific problems and failures. The older ones simply know that the thing didn't light, so they bring on the fans for safety.
Jan 01, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ignition problems. The gas will ignite, but not stay light.
When gas burners light then go out, it usually is a bad thermocouple. The thermocouple senses the heat from the burner to make sure it isn't pumping gas out without it burning.
Jan 01, 2010 | Dryers
Estate gas dryer model#TGDX640JQ2 running no heat
You may have a bad heating element,unplug the dryer. you need a 1/4 in socket driver to take off the back panel this will give you access to the guts.If your handy you can buy a new one and replace it.Tell me if you need more help.
Hope this helped.Let me know by rating me.
For more help go to live chat.
lenwest
Jan 29, 2009 | Whirlpool TGDX640P Dryer
Gas dryer
be sure burner is firing off every time it is supposed to if ignitor glows then shuts off without burner firing replace the coils on burner (2 black round things) if burner ok remove rear vent hose and try load without connected if works ok suspect flattened hose behind dryer or line to outside restricted
Jul 16, 2008 | Whirlpool LGR5636PQ Gas Dryer
Bloggett Gas Combi
either the flame sense isnt sensing the flame or the heat board is bad.go to the second burner and you will see a probe,clean it up with sandpaper and see what happens let me know
Jun 06, 2007 | Blodgett BC-14G Gas Single Oven
Whirlpool GGW9200L Gas Dryer Logo
112 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
