Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husky 38 chainsaw acts like it won`t turn over easy and can`t get it to start. turns over freely without the spark plug in.i just bought the saw and don`t know it`s history. it looks like it is new. used very little.did it to run once and it ran good.
    President:
  • 2,220 Answers
Difficult to pull starter cord:
1. starter housing. Does the starter operate smoothly? If Remove the yes, reinstall the cover and continue with 2, if no repair starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required?
· If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including; leaky intake connections at the engine or carburetor; leaky crankcase seals; or running on gasoline containing no 2-cycle oil.
· Remove the spark plug wire and plug. Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered. usually $10 - 20 at any saw outlet.
4. The last likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
Posted on Feb 01, 2010
266 se
The reason it is easy to pull over with the plug out is that there is (no compression) the air is forced up by the piston and out the spark plug hole.
With the spark plug in the piston rises up, compressing the air in the cylinder which is ignighted by the spark plug which froces the piston back down..
Basic mechanics.
May 14, 2013 | Husqvarna Chain Saw 20" Bar
Husqvarna 55 rancher chainsaw acts like it is locked up, remove the spark plug and it spins fine. what is the problem?
That sounds like normal compression. By removing the spark plug you are eliminating the compression in the cylinder therefore it will turn freely. Doesn't sound like a problem.
However, check that it is the right spark plug for the saw. If it is too long then it may enter the cylinder too far and be acting like a piston stop.
Mar 16, 2013 | Husqvarna Garden
Where can I find parts for a Husqvarna HUSKY 38 chain saw
The Husky 38 was a badge engineered machine, it was manufactured by Solo, it goes back to the early 1980s, there are no parts available from Husqvarna, so try the web as suggested
Jan 23, 2011 | Husqvarna Garden
I HAVE A 235 16"
A Husky 445 has a compression release (about the same bar length) which gets around this difficulty. We have a 435 Husky that has the same problem--your arm needs to be in pretty good shape to pull them through. We have found that the saw needs only one pull with the choke full on to be able to start on the second or third pull. Back the choke off about half to make the following pulls. Other than replace the saw, not much help I'm afraid.
Nov 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
They used none mixed gas now it won,t start is it burnd up?
Was this saw perhaps operated without oil mixed with the fuel?
· Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by the independent saw shop should be considered. HTH
Lou
Oct 30, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Ryobi 40cc chainsaw
Have you checked for spark? Sounds as though your ignition module has quit.
Remove the plug, connect a jumper wire between the threaded part of the plug and the cooling fins, Switch the ignition on, take it into a dark room and pull the starter. You should see a spark at the tip of the plug. HTH
Lou
Sep 17, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Petrol leak exhaust
the unit is flooded...pull the spark plug and turn the unit over a few times to help dry it out.problem is that the crank case is also full of fuel.you can turn the unit upside down for a day to help the fuel out.install new spark plug,don't choke it,pull the trigger to full throttle pull the recoil ten times this will pull the fuel up to top of cylinder.remove spark plug pull a couple times and reinstall the spark plug.start the unit. if the unit floods again you have carb troubles.the needle is stuck open letting in too much fuel and it needs to be replaced.let me know if this helped.
Mar 11, 2009 | Husqvarna Chain Saw 20" Bar
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
329 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
