Question about Hotpoint WMA54 Front Load Washer
My machine hotpoint WMA54 takes the water but the drum does not turn, what could be the problem? thanks
  • Hotpoint Master
  • 3,463 Answers
Could be motor brushes in need of replacement.
To check them, remove lower rear cover of washer.
Unplug motor and remove earth wire, remove drive belt.
Undo 2 screws securing motor to drum, and lever motor off
the mounts
Replace brushes if less than 3 or 4 mm long.
If brushes o/k, then could be control board problem.
Check all connections between module and motor.
Please rate my solutioin.
Thankyou..
Posted on Feb 01, 2010
Drum is not turning
Could be the brushes, only way to prove it is to remove the motor and check the brushes for wear.
If they are less than 3 or 4 mm long, then they need replacing. If brushes are o/k, then it is probably a control board fault.
Jun 03, 2010 | Hotpoint WMA54 Front Load Washer
How to change the belt on a hotpoint wma54 washing machine
there is a rear access panel in the center of the back,remove this cover and put the new belt on the motor pulley,then over the larger drum pulley,it takes some strength unless you release the motor tensioner and retighten after the belt is on
Mar 23, 2010 | Hotpoint WMA54 Front Load Washer
Locating the filter on the Hotpoint WMA54 front load washer
To check and clean the filter, you need to remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction or blockage here and in the pump as well.
Hope this helps to solve your question.
Please leave feedback.
Thanks.
Dec 12, 2009 | Hotpoint WMA54 Front Load Washer
Where is the filter on the hotpoint wma54 washing machine?
Remove lower rear cover of washer, locate and remove large black hose fastened to drum, inside you will find the filter.
Please rate my solution.
Thanks.
Sep 22, 2009 | Hotpoint WMA54 Front Load Washer
Loud niose coming from my machine when spinning
  • Hi,
  • Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | Hotpoint WMA54 Front Load Washer
WMA54 Hotpoint Aquarius flashing lights
My wife had the same problem last night.This morning when I turned the m/c on, there was a lot of noise and when I looked underneath, loads of sparking. Closer investigation shows I need new brushes and I imagine that if the drum on your machine is not turning, you do too.
However you said that you can hear the motor? That may indicate a belt problem instead. get someone to turn the machine on it's side and manually turn the drum. If the motor rotates it isn't a belt problem and someone needs to test/repair your motor.
Hope that helps a little.
Jon
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Where is the filter on wma54 hotpoint washing machine
It is in the pipe which runs from drum to pump at the drum end.
Dec 15, 2008 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Hotpoint WMA54 Front Load Washer Logo
220 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
