Question about Bosch Appliances 27 in. Wall Oven Electric Single
Door will not close tight - Bosch Appliances 27 in. Wall Oven Electric Single
  • Bosch Master
  • 3,463 Answers
If it is a drop down door with hinges on each side, then it is the hinge springs that usually cause the porblem, as they become weak over time.
The only solution is to replace both the door hinges, as they are not adjustable.
Please rate my solution.
Thankyou.
Posted on Feb 01, 2010
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Sep 01, 2011 | Neff B1421 Electric Single Oven
Can not close the door
how do you mean it won't close?it doesn't latch or are the hindges damaged and the door isn't closing tightly
Apr 16, 2011 | Whirlpool RBS305PDS Electric Single Oven
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Omega oven model number is OO910XA
If it is a common problem with Omega, they may not be ready to admit it. Since it occured 2 times, possibly the hinges use nylon rollers for smooth and quiet operation, but the hinges are not well shielded from the hi heat of 500-600 degrees and the nylon parts fail after a few months constant heat exposure. There is a common problem that happens with oven doors when they do not seam to close tight: besides being old and normally worn, if a door is leaned on while it is open, the hinges could be stretched and then they will never allow the door to close tight. This has happened to many ovens regardless of age, and the customer never realized that the weight or pressure they applied to the door when in the open position has done damage; yet they wunder why the door does not close well. Goodluck,Macgivor
Jan 27, 2010 | Ovens
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
The upper oven door dosen't shut tight.
Door not closing properly is normally due to weak door hinges.
Normal procedure is to replace both the hinges.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Thermador SC302T Electric Double Oven
Bosch Appliances 27 in. Wall Oven Electric Single Logo
264 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
