Question about Canon PIXMA MP520 InkJet Printer
NO I have the same problem as listed here "the canon pixma MP520. It says there's a paper jam but I can't clear it and the paper wonlt go through. I've got a horrible feeling something fell in and got wedged deep inside. I've used a torch but can't seee any problem at either end. I've turned it upside down but can't hear anything loose. How can I get a look inside to clear this?" but I have done all I can. I can see the paper jamming but I can not see why. I have turned it up on one end and have cleaned the rollers and have reset it several times but nothing works.
    President:
  • 2,306 Answers
You can try putting and index card or something stiff like that back thru the paper path to push back whatever is stuck. Look real close with your torch thru the spaces in the white guides that are over the long gray platen roller. Also the gray roller could have scratch marks in the area where the object is jammed. Be careful not to push back the sensor lever that is on the right side behind the white guides.
Posted on Feb 01, 2010
What is error code 5700?
I have seen this error a few times through the use of our inklink products.
The error 5700 is as follows:
This error takes place when feeding paper
from the ASF after an error occurred in the
ASF cam sensor.
Make sure that there is no paper jammed in the printer and nothing is blocking the paper path.
Oct 15, 2013 | Canon PIXMA MP520 InkJet Printer
Can I use 67 lb paper with my canon pixma mp520 printer
There should be a setting for thick cardstock or envelope that you may have to change to in yoour "prefenrences" settings. I have used heavy paper in my Canon ip3500 with no problems.
Jan 17, 2011 | Canon MP520 All-In-One InkJet Photo...
It says "Check printer" error message "6A00".
paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 11, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp520 printer says paper jam but there is no paper there
open the back rear of printer and close it again. check for debris.
Feb 07, 2010 | Office Equipment & Supplies
Error 5c00
check in inside the fusing unit by the roller.
May 12, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon pixma mp520
turn it upside down and give it a good shake
Mar 30, 2009 | Canon PIXMA MP520 InkJet Printer
Canon MP520 can print but not scan
I had the same problem. The all-in-one driver download doesn't include the stuff you need for the scanner. Go to this link (canon), click "OSX" on the dropdown list for what os you're using, then click "mp520sosxsd1391ej7.dmg" under "MP520 series Scanner Driver Ver. 13.9.1 (Mac OS X 10.2/10.3/10.4/10.5/10.6)." It doesn't take long to download and completely fixes the problem.
Feb 28, 2009 | Canon MP520 All-In-One InkJet Photo...
The canon pixma MP520. It says there's a paper jam but I can't clear it and the paper wonlt go through. I've got a horrible feeling something fell in and got wedged deep inside. I've used a torch but...
The only way to get inside it, is to strip it down (there's screws on the bottom). However, I wouldn't recommend doing this yourself unless you are absolutely sure you can put it back together again. Instead, if possible, lift the access flap (where you normally put the printer cartridges), and see if you can see anything in there (you should be able to roll the print roller yourself from there aswell).
May 26, 2008 | Canon Office Equipment & Supplies
Two-sided printing
On a PC...
- Ctrl + p to print
- Choose the Canon MP530 if it's not already selected
- Click Properties button
- Page Setup tab
- Select Duplex Printing
My paper always gets jammed, so I always uncheck the Automatic checkbox. Hopefully you won't have to do that.
Good luck.
Nov 13, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP520 InkJet Printer Logo
233 people viewed this question
old marine
old marine
