Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer goes out of balance, cannot finsh load. Bought in 2004. Not very happy with this machine.
    Problem Solver:
  • 17 Answers
Was the machine level to begin with? If it not level to start then it can keep going of balance until it is fixed.
Make sure you are level from front to back and from left to right.
Start another load and see how it works.
Posted on Feb 01, 2010
Washer goes thru cycle ok untill spin cycle gets error code out of balance, but machine not out of balance
That is not to say that the drum is not out of balance. Try running it empty and see if it happens.
Aug 09, 2013 | Kenmore Elite Oasis 27052 Top Load Washer
The digital timer on the machine will say 1 minute to go, but the machine will run on the spin cycle for 6 to 8 minutes before it finishes. Is there a part I can replace to correct this problem?
Your washer displays an estimate of time remaining in the current wash cycle. That estimate is based on the load finishing without any delays. Prior to going into a high speed spin, your washer "tests" the load balance by either rocking or slowing rotating.
If it senses and off balance condition, it will attempt to "rebalance" the load by itself and then retest, rebalance, etc. until it is satisfied that the load is as balanced as possible. Then it begins to spin. When your washer takes longer than is predicted in the display, it is because of this.
Happy washing...
Jan 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag goes out of balance and bangs loudly
This is usually due to the floor not being perfectly level, and as a consequence the washing machine not standing firmly on all 4 supports.
There should be at least 2 adjustable feet under the machine, try to make it stand as level as possible, with uniform load on all four.
If you have a bubble level it may help you establish, if there's an obvious slope on your floor and adjust the machine so that it's well levelled.
Oct 30, 2009 | Maytag HAV2557 Top Load Washer
Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Kenmore mdl 10022622100 goes out of balance
to cause unit to go off balance taking in fact that you put clothes in washer even...check your counter balance spring it hold the tub to base at rear of unit,,,and check your balance ring at the top of your wash basket its fill with water if cracked will cause this problem,,
Dec 24, 2008 | Kenmore 22422 Top Load Washer
Balancing the washer on the pedestal
Yes, ljharlow,
What is your Question?
You have a problem balancing the washer on the pedestal??
You must first balance the washer and then put it on the pedestal!
I take it you bought and picked up an installed your own machine.
The delivery men know to do the leveling foirsy and then raise them on to the pedestal
If you have two people you can have one person lift the front of the machine by tilting it back wards on the pedestal so the front goes up in the air a little and the second person turns the adjustable legs till it is level! If you laid the washer on its side ,front,or back at any time since you bought it then you threw the machine out of balance and YOU DO need service to correct this situation!!!!!!!
bless you Huuum
Please rate me on our site for my good advice before you sign off
Sep 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LSR8233EQ0
Check base mount springs, there are 3 from base to tub and 1 from tub to back bottom for counter balancing. If all are ok then you will have a skid plate problem. Best to call for help.
Jan 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer goes into unbalance mode
Check the springs and spring mounts,(might be broken or not on right), also could be something wrong with the balance switch (where the tub hits the switch).It could be mis aligned or defective. Check the springs first.
May 13, 2007 | Whirlpool AWM6120 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
