Question about Sylvania 6620LFP 20 in. EDTV-Ready LCD Television
Manual, and channel select....
I have had the above tv given to me used from a garage sale, it seems to work okay but it does not have a remote nor a manual, i have basic cable tv and can't seem to find a way for it to select the channels, I go to the menue and slect channel set but get nothing....and or where can i download a manual...i would appreciat your thoughts
  • rjmack2249 Feb 21, 2008
    thanks loads, i think i would never had figured that out, with out a manual..and the link was great too!
    rj
  • 31 Answers
Once you get to the Channel Setup menu push the Volume UP button and that will take you to the Auto Preset search that will add in your channels.
For more information refer to page 3 of the manual listed below.
The manual is available from here:
http://www.manualshark.org/manualshark/files/21/pdf_14693.pdf
Posted on Feb 21, 2008
Pioneer plasma model PDP-507XA. how can I tune a TV channel?
The PDP-507XA only has an analog tuner. You will need a set-top box (digital to analog converter) to receive over-the-air signals in most places. For analog cable, you need to set the source to TV. Press the Select button, if needed (it's above and to the left of the arrow keys), to put the remote in TV mode. There is also an Input button on the TV. If the Channel Up/Down keys do not work, you need to reset the TV Press the Home Menu button. Navigate to the Setup menu (Up/Down arrows followed by Enter) and select Auto Installation. Enter your password for the TV; the default password is given in the manual on page 41. It's available from Pioneer here: docs.pioneer.eu/Manuals/PDP_507XA_ARE1430_manual . Set the Language (use the Up/Down arrows followed by Enter. Then use the Left/Right arrows to change the setting). Then set the Country. Press Start to begin a scan for channels. Alternatively, select Analogue TV Setup and enter the password. Then identify the correct receiving system. Manually enter the channels in the Search area. Set Store to Yes to save channels.
I hope this helps.
Feb 14, 2016 | Pioneer Televison & Video
Was given a big screen sylvania srt2432p with no manual. Can't seem to figure out how to enter anything from the manual mode to set channel to play DVDs. Handheld remote does not seem to work-...
Hello
Just get into this site from you can download the user manaul of your Sylvania Tv. I think that to select the inputs, you must have its remote control. If there is a "Meny" button on the front panel of your TV, you can select it. Just download the manual and go through it. It is absolutlely free download. OK.
www.manualshark.org/s/sylvania+manual+mts+sap/page:2
Sep 10, 2011 | Sylvania SRT2432P TV
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
Not receiving signal from remote control
I have a new remote from a C1300NTVD Lightning McQueen car TV for sale. It's probably the same remote for a C1320PTVD.
Chris
email me: chris_goulet [at] yahoo [dot] ca
Apr 28, 2009 | Disney CARS 14 TV/DVD Combo
Early 2000's AKAI ATV 140 (Tv / Video Combo)
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Mar 31, 2009 | Akai LCT2701AD Television
Mitsubishi diva cant tune in
well .... no online user manuals for thoseTVs
you will need to use a digital seck top box and use that units remote to tune the TV
if there are any (needs a user manaual)
use the buttons on the TV lower casing
to tune up
none of the all in ones remote buttons work for all TVs functions
you are lucky if it turns on and off
and changes channel
Apr 29, 2017 | Mitsubishi VS-45609 TV
Resetting Channels without Original Remote
Buy a universal remote.
or
If there is no input button on the remote or TV, try the channels between 90-110, some RCA TVs have the A/V in there somewhere.
http://www.ecoustics.com/electronics/forum/home-video/134340.html
Oct 11, 2017 | Televison & Video
Tv does not respond to channel changes
The simpliest solution is always the best - I called the cable service provider; they reported an outage and quickly remedied the situation - but also tried to sell me their digital TV package. Thanks for your response.
Feb 16, 2008 | iLO 3200 32 in. LCD Television
Eas tv model et427e
Using your TV remote (not the cable remote) use the input/select button to swtich to videe 2 or ? ; this should allow DVD to work/ when done use remote input/select button and switch back to video
Dec 23, 2007 | Televison & Video
Sylvania 6620LFP 20 in. EDTV-Ready LCD Television Logo
271 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
