Question about Dell Wireless Keyboard Optical Mouse w0147
My mouse was working and stopped. the batteries are charged and the lights are on but no action
    Sergeant:
    Champion:
  • 232 Answers
Hi cassjilek
Good job on checking the batteries, always the first thing to do when dealing with wireless devices! Next thing, have you tried the 'pairing' sequence again? If you flip the keyboard over it should show you what buttons to press and in which order. Follow these EXACTLY and the mouse should spring in to life.
Good look and let me know if you need any more help.
Scott.
Posted on Feb 01, 2010
I have 2 computers both with mx700 mouse and they have worked great for a few years. All of a sudden, both have stopped charging. The green light blinks to say it is charging when in the cradle but within...
I assume you are using usb socket to charge mouse. The voltage on a USB is 5volts , you may have a problem here. It may not be producing the correct voltage. Or you may have a problem with your cradle. I would suggest you see a repair person and get them to look at the USB voltage and the Mouse cradle..
Hope this helps.
Feb 18, 2011 | Logitech MX700 CORDLESS OPTICAL MOUSE...
LIGHTS ARE ON CURSOR DOES NOT WORK HAS BEEN WORKING FOR 2YEARS WITH NO PROBLEM .HAVE ALRADY UNPLUGED AND RESTARTED ALL SYSTEMS. IT IS AN IOGEAR GKM531RA WIRELESS. KEY BOARD IS WORKING FINE -BATTERIES IN...
The GKM531RA comes with a USB dongle which is connected to the computer.
Since you mentioned that the batteries are okay. Locate the small button on the dongle (connect button) and look for the connect button underneath the mouse.
Hold the connect button at the same time for 5 seconds ONLY, and release them both. The mouse should work.
If that did not help, try to use the keyboard and mouse in a different computer.
Last, contact IOGEAR and have them RMA the device. Meaning that the mouse has a hardware defect.
Thank you and good luck!
Dec 25, 2009 | IOGear (GKM531RA) Keyboard and Mouse
Mouse stopped working, light but no action
Ok if this wireless you need batteries or to check the connedtion. Swing by the control panels and check to see it the mouse is recognized and if it needs software run to the download section and make it happen
Oct 13, 2009 | Computers & Internet
Wireless mouse stopped working. green light works
This can happen when the battery's are starting to die. Replace the batteries and then test the device again.
Oct 09, 2009 | HP Wireless Optical Mouse
Wireless laser mouse stopped working. KB OK. Tried Everything
Under the mouse near the optical lens there should be a small connect button, press that and the button on the receiver too.
Also make sure the batteries in the mouse are new or fully charged.
Good luck
Jun 28, 2009 | Logitech Cordless Mouse
Plug receiver into different USB port and re-connect...
Mar 16, 2009 | Labtec Wireless Desktop Keyboard/Mouse...
My new Nexxtech NWOMMI cordless mouse is not working
Here is what I found about the Nexxtech Notebook Wireless Mouse (NWOMMI):
1. The 2 AAA batteries must be inserted correctly. Look carefully at the "+" and "-" marking on top of the battery compartment and put your batteries in accordingly. Otherwise the mouse will not work, and could be damaged. After the batteries are inserted, the red light at the bottom of the mouse should come on. More on batteries below.
2. Insert the USB receiver into a USB port. The blue light should come on. Press the little button next to the blue light and the light should start to blink,
3. Whild the blue light is blinking, press the connect button at the bottom of the mouse. It is the big black dot inside the white label. Check that the blue light on the receiver is blinking faster, and then change to a steady light.
4. Now check the function of the mouse by moving it on a texture surface.
5. If all goes well, your mouse should be working.
However, here is the bad news. Either due to bad design or some flaw in manufacturing, the mouse consume batteries like crazy. I used fully charge NiMH AAA batteries and they last for only a few hours! And the worst part is that, I checked the batteries when the mouse stop working, ONE of the batteries is COMPLETELY drained, in fact it registered a reverse voltage of -0.1 volts (a charged values is +1.2 volts). This is definitely engineering problem. Note that even when the batteries are in this state, the red light may still come on, and sometimes the re-connection seems to be ok (i.e. the blue light blink faster and then changed to steady). However, the cursor will not work when you move the mouse! Recharging the batteries and the mouse will work again.
Based on the above observation, the mouse instead of having a power-saving feature, it actually has a power-wasting feature!!!
Nov 12, 2007 | NexxTech NWOMMI Mouse
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Dell Wireless Keyboard Optical Mouse w0147 Logo
105 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
