Question about Lutron 600-Watt Multi-location Dimmer Switch by Electronics, Inc
The switch quit working and when i turn on my micro-wave it went
I just had the switch replaced and it doesn't work again.
  • 127 Answers
What type of bulbs are you using? Most compact florescents (CFL) won't dim at all. So, make sure the bulbs being used are "dimmable".
Also make sure your bulbs accumulatively don't add up higher than 600watts. Really you want to stay at 500watts or lower.
Hope this can get me a 4 thumbs up!
Posted on Feb 02, 2010
SOURCE:
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My roof on my mercedes slk goes up ok but the windows stay down and the swich flashes
The micro switches for the hard top latches are bad and not sending a closed signal to the control module. When they stop working the control module doesn't know the top is closed so it doesn't raise the windows. Those micro switches are known to go bad. I have changed quite a few of them before.
Apr 20, 2011 | 2000 Mercedes-Benz SLK
My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
Oct 30, 2010 | Emerson Microwave Ovens
Micro wave stopped heating. All other features
Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
Microwave over the stove
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
It may also be a problem with a door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 27, 2007 | Frigidaire GLMB209D Microwave Oven
Micro wave just quit working
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 28, 2007 | Magic Chef MCD1311ST Microwave Oven
Lutron 600-Watt Multi-location Dimmer Switch by  Electronics, Inc Logo
93 people viewed this question
Top Lutron Electrical Supplies Experts
jdthefixer
Craig Butler
Craig Butler
mikenearman
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
