Question about Samsung DLP HL-P5663W 56" TV
MY PICTURE SHUT DOWN AND THE LAMP LIGHT IN LOWER RIGHT HAND CORNER IS ON. THE FAN HAS ALWAYS MADE A LOT OF NOISE AS WELL. OLY HAD THE TV 3 YRS.
  • Samsung Master
  • 8,457 Answers
It the colors wheel,must replaced DLP samsung have alot of colors wheel misalign make noise.
Posted on Feb 03, 2010
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Picture has become darker and darker, but now there is no picture or sound a red flashing red light in the lower right hand corner.
Time to replace lamp in tv.
Existing lamp in tv is dead and tv needs new lamp to work again.
Lamp replacement procedure is easy and written in user manual of tv.
Oct 10, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
We own a Samsung DLP-TV. Last night it started shutting itself off. WE changed the lamp, but it is still shutting itself off after a minute. First, the picture goes off black, then the entire TV shuts off....
Do you still have your old lamp? try to see if it still works.. i think the problem could be something with your Ballast or maybe the color wheel.
Does your TV makes a strange sound? if it does maybe one of those 2 ballast or color wheel.
LETS TRY THIS....... MAYBE IT WILL WORK.
the Door lamp switch could be faulty, you've got to check it need to close fine with out the switch to go down
here is a picture that i found it looks like this!
and if not.. you can probably call this number the will give you free service.. i have tried it before =] (800) 281-8860
Mar 09, 2010 | Samsung HL-T5675S Television
Red light on front flashes 4 times and picture comes on for 1 second then goes dark and red light flashes
THE FOUR BLINKING RED LIGHTS INDICATE A FAN PROBLEM. CHECK IN THE BACK AND MAKE SURE THE FANS ARE SPINNING ON POWER UP.THE PROBABLE CAUSE IS THE LARGE LAMP FAN LOCATED ON THE LOWER LEFT WHEN LOOKING AT THE BACK OF THE TV
Dec 15, 2009 | Sony KDS-R50XBR1 50" HDTV
Samsung dlp hls6186w, picture has darkened, could it be the lamp or is it the colour wheel??... tv is making sounds...I thought it was the fan, the fan looks okay??? It also shuts down once and a while...
The lamp is the only thing that will cause the picture to go darker. According to the model you have the lamp part number is BP96-01472A. The noise you hear could possibly be the color wheel itself. The way to tell is when you turn off the TV the lamp stays on for about 10 seconds longer. Once the lamp shuts off if that noise goes away then it is a bad color wheel. Any noises past that would be a fan. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Samsung HLS6186W 61 in. Plasma HDTV
My Sansung HL-S4266W just shut off one evening while watching. It had all 3 lights blinking and it had been over 3 years since buying the tv. I replaced the bulb, nothing changed the tv would still turn on...
this could be the color engine or a power supply problem. My suggestion is to not put anymore money into this tv, its an old technology and you will be replacing parts for it every 3 or so years. eventially the parts will not be able to be found. Go get a new tv, save yourself money and headaches.
Jul 17, 2009 | Televison & Video
Lamp light blinks 3 times shuts down
The CLS problem. Im thinking that at least you made a visual inspection of the power suply and the capacitors around it. Then if everything normal in the area then the microdisplay (inside the ligth engine) can be damaged. (when the tv is working normally the microdisplay sends a pulse to turn on ballast and lamp finally.
The sweetkyman: when the fan is bad th tv shuts down imm. (if you unplug the fan when the tv is working normal the computer detects the overcurrent system works and shuts down the set) when a fan is all dirty and tons of dust on it the tv tends to work but after some hours the tv shuts down.
Dec 20, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Yellow spot in lower right hand corner
You have pretty much narrowed it down to being a bad optical block. This isn;t good news, since the optical block is probably the most expensive part in the set. Your best bet is to contact Sony customer support to see if the will allow some kind of accommodation for the repairs. Sorry for the bad new; hope it doesn't effect the rating you give me for the solution. Thanks!
Nov 11, 2008 | Sony Grand WEGA KF-42SX300 42" LCD TV
Samsung DLP Tv
it's about 3000 to 5000 hrs. on the bulb this translates to about 3 to 5 yrs. of normal use. it can, however, be greatly reduced by the number of on/off conditions. lamps need to cool down that is why the fans run longer after shut down.
obviously if the TV doesn't turn on that can be lamp. weak or dim picture is another sign.
Jan 22, 2008 | Televison & Video
Samsung DLP HL-P5663W 56" TV Logo
111 people viewed this question
Henry  Thomas
Henry Thomas
