Question about Whirlpool Duet GHW9150P Front Load Washer
Does not heat. all other functions work. - Whirlpool Duet GHW9150P Front Load Washer
  • 3 Answers
Replaced the heating coil for $59 and it now works perfectly. It was an easy replacement. I also replaced a couple of adjacent parts (thermal couple and sensor I think they were called ?) as they are known to go out and as I already had the machine apart and going to the supply store I invested an additional $38 to replace them. Looking up the manual online showed pictures of the parts and stated the symptoms very clearly providing a better level of confidence to takle the task.
Posted on Feb 02, 2010
I have just installed a RTH7400/RTH7500 thermostat. The wires are seem to be in the correct place, all functions are working, with the exception of no heat will come out, only cold air? I have set all...
Check function 0170 to make sure it is set on the proper type of heating system. Its a long list and specifics of system type make a difference. Also, Ive learned the hard way to always go by function, not color of wire. If you tossed the instructions they can be found on the Honeywell website https://customer.honeywell.com/resources/techlit/TechLitDocuments
Nov 16, 2017 | Honeywell Focus 6300B 5-2 Days...
Unit will not heat up
check contact points for current. tabs might be bent and are not contacting correctly and no heat the Ni-Chrome wire heats up glow orange when currant is applied , might need a test voltage Meter and screw driver too >^.^<
Mar 14, 2010 | Kenmore Microwave Ovens
Although all systems seem to function,(fans lights clock,grill etc.) it does not heat on the MW mode. My wife turned it on thinking it was full when it was empty and heard a Sparking sound. Model WM...
If there is no heat but all other functions work, then the magnatron is likely faulty. The magnatorn provides the heat. You can get one at repairclinic.com or partselect.com
Dec 07, 2009 | Microwave Ovens
Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Mar 11, 2009 | Heating & Cooling
Heat relay in coleman air conditioner not functioning
You have stated the the heat relay is not functioning. If the relay has no voltage when you set the unit to heat then the relay may not be the problem. However if voltage is present and the relay is not working then you are correct that the relay needs to be replaced.
Feb 19, 2009 | Coleman Heating & Cooling
Friedrich YM18J34 will not heat
Sounds like a bad limit switch. Open and test continuity on all limits with power off and at least one wire off one side of each
Jun 17, 2017 | Friedrich TwinTemp YM18J34 Air Conditioner
Microwave functions but will not heat
CHECK THE HIGH VOLTAGE FUSE AND THE MAGNATRON IN THE UNIT !!!!!!!!!!!!!!! DISCHARGE THE HIGH VOLTAGE CAPACITOR OTHER WISE THE VOLTAGE STORED IN IT WILL KILL YOU!!!!!!!!!!
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
Whirlpool Duet GHW9150P Front Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
