Question about Dell UltraSharp 1907FP 19" LCD Monitor
I have a dell 19-7 fp monitor that only stay on for a few second and then shuts off
  • 11,361 Answers
The problem can be caused by bad caps in the power supply, bad inverter circuits, or bad lamps. You need to open it up and look inside and post back so we can guide you further, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 01, 2010
Dell 1900 fp monitor driver
Go to GOOGLE and type DRIVERS for your exact product and model of monitor, which will hopefully give you the correct drivers to download. Softonic would be one place to look. CNET would be another.
Sep 19, 2012 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
THE MONITOR WILL NOT STAY ON. IT KEEPS SHUTTING OFF. WE CAN TURN IT BACK ON AND IN FEW SECONDS IT SHUTS BACK OFF. WE TRIED A DIFFERENT MONITOR AND THAT ONE DID NOT SHUT OFF. SO, THE PROBLEM HAS TO BE IN...
Whenit power up and stays if the display picture is good, the fault can be a dry soldering, poor joint or a thermal runaway of one of the power circuits.
In all the above you can open the monitor , tap and see or look with a magnifier for visible dry joints.
You can also check if any semiconductor or IC is heating up beyond to shut off.
Sep 29, 2010 | Dell E193FP 19" LCD Monitor
Monitor suddenly died..replug it and it has power for a couple of seconds but then no power..is the ac adapter the problem and needs replacing? or is the monitor history?
no no the monitor is not history yet :)... it's your adapter maybe. try holding the adapter tightly when you insert it. check the monitor while holding the adaptor.. that should help you find out
Aug 01, 2009 | Fuji FP-988D 19" Flat Panel LCD Monitor
Power almp blinks
i have this problems before its an inverter problem. pls. repair the inverter.
Jun 28, 2009 | Dell E173FP 17" LCD Monitor
The screen went black after few seconds.
Hello Chris,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the strip on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | Dell E193FP 19" LCD Monitor
Monitor will not stay on
I am having the same issue. Stays on for 2 seconds then goes black. If I find a solution I'll let you know.
Apr 07, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Whats the meaning of a Dell Ultrasharp FPt 19" Monitor and a FP
It just the teminology used in dell flat panels e.g. FPT and FPV
FPV ( flat panel with Vesa mounting holes)
FPT ( Flat panel with Tilt adjust )
Thanks
proton
Nov 04, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
507 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
