Question about Panasonic (TYSP32L7WS) TV Speakers
Panasonic TXL37G10B --Poor sound despite trying all sound adjustments. Sound appears to "echo" as if the broadcasters have a bucket over their head. Any ideas or are all modern "flat screen" TV`s l the same ?? Couldn`t listen to sound in the shop and the picture was better on the shop aerial than on my aerial ! Kind Regards , Guy.
I`ve gone back to my old CRT telly & "freeview" box.
The retailers [ Appollo ] didn`t have an engineer and they expected me to take the TV back to their shop in order that they could then send it away to a repair shop, some 20 miles away, for appraisal !!
Too much hassle and potential for risk of damage,etc.
Problem solved for now,
Regards, Guy.
Posted on Feb 02, 2010
  • T Rick May 20, 2014
    New TVs sacrifice sound quality because the enclosures are so thin. That's the reason sound bars are so popular. You could've purchased even a moderately priced one and improved your sound quality.
No color on my Panasonic plasma TV
Try to adjust the input, for example hdmi or scart .
Try to connect a peice of equipmet you know works with colour , ie dvd, plastation, vcr , and see if it makes a difference
You did not say if it was like that all the time , ie on normal tv
Feb 03, 2016 | Panasonic Televison & Video
Poor audio with Logitech Quickcam Pro 9000
What type of internet connection do you have and also at what speed? How is the video quality?
Feb 21, 2008 | Logitech Quickcam Chat Webcam
Echo through speakers
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
Sep 15, 2012 | ASUS Computers & Internet
I can't figure out how to make a headlight adjustment. it is too low
On most older motorcycles a major adjustment was made by loosening the two headlight bucket mounting bolts on the side and tilting the whole bucket upward to change the angle. Side to side was done by turning a long screw. On your model the headlight bucket is solidly held on by two long bolts on the bottom of the head light. There is one adjustment screw on the front of the head light bucket. There also appears to be an adjustment screw inside the headlight bucket that is only accessible if you pull the headlight out of the bucket. Remove the headlight from the bucket by removing the two holder screws and use the inner screw to raise the angle of the head light. you may have to do this more than once to get it right. The pieces may have come loose and are sitting in the bottom of the bucket. The adjustment screws both have springs on them and are part #'s 4 and 5 on this diagram. http://www.bikebandit.com/houseofmotorcycles/1998-honda-vf750c-magna/o/m2761#sch100698
Jun 15, 2011 | 1998 Honda VF 750 C Magna
The speakers sound like an echo and you can't understand what is being said with everything being distorted. The monitor has not been in use for a few months and everything else is working properly, but I...
Have you checked the sound with some other speakers or a headphones.
If the sound is still like echo try adjusting audio settings not thru My Computer - audio, but try finding a software that comes with *********** board/sound card. I suppose the sound is some AC97/Realtek compatible card, so you should looking in your program files under Realtek into WDM and run the Audio Control Panel or Sound Manager (whatever you find). Adjust the sound effects to NONE and use some normal enviroment (other then echo/cave/big hall).
May 22, 2010 | ViewSonic Computers & Internet
I have a panasonic TH-50P V600 TV, the sound in
by any chance do you have the set in suround sound if you do change it back to stereo.. and try that most of todays set have poor sound and tiny speakers. because so many people connect there set to a theater system
Dec 04, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
My pc sound system has a bad echo..
try uninstalling sound drivers and reinstalling them (or newer)
Nov 13, 2007 | Compaq Presario 5000 PC Desktop
No sound or vision playback of dv tape
From my poin of view cyliner (rotary head) have poor conection or this parts will be replace.
Aug 06, 2007 | Panasonic NV-GS11B Mini DV Digital...
Panasonic (TYSP32L7WS) TV Speakers Logo
200 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
