Question about Xerox DocuColor 12 Printer
Black is very bad,
My dc 12 printing very bad black color
    Champion:
  • 241 Answers
Bad means to poor
then check ink supply for black
check cartridge motor by removing black cartridge and inputing component test code 009-011 does it rotate black cratridge moter
similarly for dispense motor 009-031 for lower side gear
Posted on Mar 29, 2010
I owned HP CM1312 mfp. I have problem with color prints. No any color is printed except black. I changed dc controller but the problem remains... Could you please help?
I hope you did calibration..The Flat cable from laser scanner assm to DC controller is very short & narrow, while connecting it to DC board little bit it will come out at scanner assm PCB, remove upper portion up to laser scanner assm refix flat cable both ends of DC & laser pcb. fix all back & try.. I hope it will resolve the issue.. Best of luck...
Sep 27, 2011 | HP Laserjet CM 1312NFI Color Printer
Colors are wrong. Cartridges say I have plenty of toner in each of the 4 ...but when i print the colors are not right. I did a color test and the yellow is barely visible. How accurate are the sensors that...
Each cartridge has a "memory tag" that keeps track of the cartridge use. It is highly unlikely that all 4 memory tags are bad. Are you using HP cartridges?
Have you calibrated the printer? Do a full calibration.
It is possible that the DC Controller is bad. Each of the "memory tags" reads and writes to the DC Controller. The DC Controller also determines which colors get printed. Have you changed the ITB (Intermediate Transfer Belt)?
Mar 31, 2011 | HP CP3525N Color LaserJet Printer
Free solution of black bars on paper while printing on xerox dc 12 printer
Most likely this indicates a drum cleaning blade failure. This is especially true if the black Bars run up and down the page and get worse on multiple copy runs. So if you run 10 copies the last one out will be worse than the first one out. If this is the case, cleaner blades are pretty in-expensive at around $40.00.
Good Luck and Thank You for using Fixya.
Sep 10, 2010 | Xerox DocuColor 12 Color Copier
What is the solution of black bars on paper while printing on xerox dc 12 printer
Most likely a drum cleaning blade. If the streaks are verticle, up and down the page and if they get worse as you run multiple copies. So on a 10 page copy run the last copy out will be worse than the first. Cleaner blades are cheap at around $40.00
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
Dc 12
go to the xerox website and download a patch 1-7kv9 or something similar. The description of it is listed under support and drivers and it comes with instructions. You need command workstation to invoke this patch. If you cant find it let me know, or tell me your email and i'll send it
Oct 29, 2008 | Xerox DocuColor 12 Color Copier
Cranking noise when is turn on
We had this same problem.
A tech had to come in and replace a cog in the back.
Nov 20, 2007 | Office Equipment & Supplies
Xerox DocuColor 12 Printer Logo
106 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
