My DTH109T player doesnt work anymore. The two led
My Thomson DTH109T player doesnt work anymore. The two led start blinking. Maybe its an error code. Do you have any idea?
4 Suggested Answers
SOURCE: 3110c doesnt start anymore it just blinks and then turns off
your cellphone have a problem with your lcd.you just need to go in the cellphone mechanics.
Posted on May 11, 2009
SOURCE: Thomson scenium LED error code 45
When i turn it on red light flashes 3 times then 1 time, this keeps on repeading, no sound, no light
Posted on Aug 26, 2011
SOURCE: iv got an nsm performer
i have the same one . i get a po 41 err 31 anybody know what that is ?
Posted on Nov 09, 2011
LCD TV does not turn on from first time
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 08, 2016 | Panasonic Televison & Video
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
What does 3 flashes on the standby light on a Thomson scenium 44jw 611s mean
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Feb 25, 2015 | Thomson Televison & Video
In Thomson CTV smps having a problem during start
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continues without any pause, the main board is faulty.
Oct 10, 2014 | Televison & Video
Can i download asetup/installation for thomson digital recorder
Sep 14, 2014 | Televison & Video
Dell D600 when powering, leds blinking
Its a motherboard problem. check all the flashing codes here.
CLICK HERE
it will give you all the information about the codes.
Sep 26, 2009 | Dell Latitude D600 Notebook
Error code erased whith a smartbox
it could just be a slack cable that needs sorting, or maybe you have struck it lucky and its just warning you to stress you out sometimes the way a woman dose, weithout seeing the error for my own eyes its difficult you may just be fine
Jun 05, 2009 | 2004 Honda Accord
47wx42f panasonic tv
Does the led blink when you press power? If so please let me know the number of blinks as that is an error code.
May 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic pt-50dl54j
The 3 times LED code points to no fan rotation. There are 2 fans. Check the larger fan first, p/n = FBL12G12LS, located near the lamp. Even though that fan may be rotating, it may be slow.
thanks
scott
Dec 20, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
