Question about Acer DX900 Smartphone
Hello these are my previous comments.... My acer dx 900 pda wifi indicator does not shut off, and as a result i think thats one of the reason the battery dies so fast. when the wifi button is selected in comm mngt it does not respond, so in a nut shell no wifi, battery dies fast, phone reset all data settings if it shuts off or restart. what can be done do i need a upgrade to wm 6.5, if so how is it done step by step Comments: Feb 01, 2010 - i cant seem to get these patches open i am using a mac, or do i have to download the patch on a pc? Feb 01, 2010 - i cant get the patch download Solution #1 posted on Feb 01, 2010 Report Abuse 2007nfm 2007nfm Rank: Guru Phones & Accessories Expert Rating: 93.60% , 57 votes wouldn't want to think that its purelly the indicator that is causing battry to die fast. Get a patch from here for your set. also check here for more instructions. Regards Comments: Feb 01, 2010 - Download patch to your pc, unzip using winzip or winrar, send the unzipped fplder to your dx900. your handset( smartphone) will identify it once you try to open it and install the patch. Regards Feb 01, 2010 - Did you navigate to where there are 3 patches? I would recomend you only download and install the one for battery life only if your phone otherwise works well. I am otherwise moving out of office. its now 6:00pm here. so untill tomorow 8:am BUT MY REAL PROBLEM I NEED THE WIFI TO WORK
  • 5 more comments
  • express72 Feb 02, 2010
    Yes sir i have tried the soft reset and cold boot and its still working the same. i also tried updating the battery patch you sent me but unsuccessful, its saying a previous version will be deleted and when i tell it ok, it says unable to delete and do you want to install anyway said yes and it install but i a not sure if there are two version on it or whot...but like i say the battery is not the problem, its the wifi. so maybe we can try the rom upgrade..... this is the info from the phone in the about tab....
    Windows Mobile 6.1 Professional
    CE OS 5.2.20772 (Build 20772.1.4.7)
    Processor: ARM1176 S3C6400
    yes
    Yes tried the cold boot and the soft reset. same problem with the WIFI. maybe a rom upgrade might help. this is the info on the phone...
  • express72 Feb 03, 2010
    yes i did but it appears to be wm 6.1 instead of 6.5 so the problem still occuring, which is the WIFI light is on but not activated
    sometimes after a couple of soft reset the wifi light will go off and it will function normal. but is the phone has to turn off or reset for whatever reason the problem will happen again.....the time here is 10:50 am
  • express72 Feb 07, 2010
    Hey,
    I downloaded a beta version wm 6.5 rom from this link acerDX900 WM65 OS 21882_Beta_4.7z acerDX900 WM65 OS 21882_Beta_4.7z . try to install it but think it needs a boot loader in order to get it work or maybe you can check it out and let me kno how you think it can be done....i read about it on a forum this the original link..http://www.eten-users.eu/index.php?showt...
  • express72 Feb 09, 2010
    Hello i think i mess up my tempo dx 900 see the info bellow... I tried the 28011 eng dwn load which was successful until i
    restart my device ..... it is stock on the goldfish screen...any way to
    reverse the fix that or reverse the process?
    Moin,
    here are the newest versions of the OS for Glofiish V900 and X900. In
    most cases V900 users should install the app "MobileTV" after
    installing the actual OS version, because this app isn't integrated in
    the ROM. So you can decide by yourself if you want to install the app
    on the device or on the SD-Card.
    Installation:
    1. Rename the "V900X900_WM65_xyz_temp.dat" to "temp. bin".
    2. Copy the "temp.bin" to the root of an empty fat16-formatted SD-Card (1 or 2 GB).
    3. Insert this SD-Card into your device.
    4. Remove the phone SIM-Card.
    5. Press the buttons POWER and VOICE simultaneous and hold them.
    Press short time the RESET button while still holding the other
    buttons. After releasing the RESET button and further holding the both
    other buttons there will appear after a few seconds on black screen the
    info:
    USBDL_V900_04LB_01_16 (LP)
    File= TEMP BIN
    After this point the Installation begins and needs some minutes.
    6. After the message
    Waiting a download
    remove the SD-Card and make a hard reset by pressing the POWER and RESET simultaneous.
    Here is the newest OS version:
    28011 English V1.0: http://netload.in/da..._WWE_V1.zip.htm
    28011 German V2.1: http://netload.in/da...ER_V2.1.zip.htm
    Here is the app "mobileTV" for V900 users only (newest version):
    http://netload.in/da...obileTV.zip.htm
    - Thunichgud -
    Dear friends,
    for further requests of later OS versions, I need three things:
    1. a link to the temp.dat file of the requested version. It must be the temp.dat of the V900 / X900, no matter the language.
    2. a link to the package of the requested language version belonging to the requested OS version (WWE = 0409).
    3. a link to the german language package (GER = 0407) belonging to the requested OS version.
    I can't download from chinese websites and I can't download from Rapidshare, Mediafire.
    Downloads from: Upload.to, sharingmatrix.com, 4shared.com, easy-share.com and netload.in are possible for me.
    Without german language package, I will not make further versions.
    - Thunichgud -
    _______________________________
    Hey, I tried the 28011 eng dwn load which was successful until i
    thnx
    esjay..
  • 2,069 Answers
Ok, sorry about me informing you that i was moving out of office, but iam now back so that we proceed with the solution i was providing. Did you manage to install the patches? if yes, did you get any changes in battery life? please respond as i compile a solution for your wifi problem. and once again, Iam sorry, couldn't finish up yesterday but I've just come back to office.
Regards
Posted on Feb 02, 2010
  • 4 more comments
  • Muzahura Frank Feb 02, 2010
    Focussing on wifi probplem,
    I assume you have previously done a soft reset now try out a "Cold boot"
    please follow the procedure on This pdf manual page 272 on how to do a cold boot.
    Before you perform the cold boot operation, please first backup your important data first.you can back up in many ways including using the backup utility provided within your phone or using any windows smartphone sync manager. please read about back up on the same document.
    If after this, the problem still persists, please inform me again so that I give you the procedure on how to do OS (ROM) upgrade. check which version you have and inform me; this is how you will check;
    Start>settings>on
    system tab,tap About> in version tab,make note of the information in
    processor. Take note of the ROM version. please note that From Acer website, the latest version available is A147.040.0553.
    Kind regards
    From Acer website, we
    are going to download
    this english Rom version A147.040.0553. its about 83mb.
    We shall also use windows mobile sync manager from HERE and a good internet connection.
    Install the sync manager and follow instructions on the sync manger site on how to upgrade your devices firmware.
    And again, just like yesterday, I have to move out of office its 6:pm. please keep this thread open to me untill I fix your problem.
    Regards
    Also go HERE for other details.
  • Muzahura Frank Feb 03, 2010
    Hi, did you manage to upload the updated ROM version?
    It seem we have time differences but please leave whatever comment you can so that i respond to it when I'am on line.
    Regards
  • Muzahura Frank Feb 04, 2010
    windows mobile version 6.5 is available HERE. Acer would probably be the right download place but the version you just installed is the highest for your phone available from them. however check on the above link.
    Also, as you indicated above that after some couple of resets your wifi works and later goes back, that indicates a failing wifi hardware. normally, a simple hardware service, fixes the problem. so i would recommend opening the phone, service the motherboard components using hot air blower over the ic's at moderate temperature.
    Regards
    windows mobile version 6.5 is HERE.
My wifi connection is good, but why is the wifi signal by the power button orange now previously it was blue? is this somthing i can manually fix? help
Orange indication means that the wifi is off or disabled. This will occur if:
1. You manually disable the wifi driver
2. You disable the wifi using the keyboard function key
3. You plug the PC into a wired network connection.
Check the keyboard hotkey for wifi and cycle it to see if for some reason the wifi was accidentally disconnected. If that is not the case, check the device manager to see of the wireless network driver is installed and working properly.
Dec 10, 2015 | Acer Aspire Computers & Internet
Why does my Galaxy dx-66v lose power for no reason ?
could be a number of reasons but the one I think of is a capacitor on its way out. check for leaking electrilytic caps . Could also be diodes or transistors ,even resistors .
Feb 07, 2013 | Galaxy Radios DX-66V Base CB Radio
TOSHIBA PORTEGE G910 POWER MANAGEMENT problems
try xdadevelopers for this solution,best site for xda pda problems
Mar 23, 2010 | Computers & Internet
Acer Aspire 4930G Keyboard touchpad not responding? Cursor responds with external mouse, keyboard responds in dos mode. keyboard and touchpad are not present in device manager, system restore is useless in...
in my opinion. your touchpad driver is defected by virouse /re install once time it, second your computer touch pad hardwere is damage,check it using by another keyboard and mouse. then u can get result --thanks
Jun 13, 2009 | Acer Aspire 5101WLMi Notebook
WIFI SD CARD
Test the network capability - ping your card and also do an auto detect through home network set up.
If it still doesnt feature, unplug, reboot phone and replug. shoul;d work!
Mar 11, 2008 | ASUS MyPal A626
Acer n300 wont sync
you also have a connection manager on the PDA Itself ( Active sync ) Try syncing from the PDA as Well As The Computer Active Sync Program.
Also make sure if you have a firewall, you allow the PDA into it as a trusted Device.
Mike @ Compurepair.
1 more thing, try on/off the PDA whilst in sync mode.
Hope This Helps.
Feb 21, 2008 | Acer N300 Pocket PC
Acer 3003LCi - Wireless Connection
It seems the two oval lights on the front of the Acer TravelMate 3003LCi are not only lights to indicate WiFi traffic, but also buttons to turn the WiFi radio on and off for security reasons. If you press and hold the left side button for 3-5 seconds it should turn back on the WiFi radio. Windows XP (and maybe other OS’s) have a power saving function that turns the radio off when not in use to save the battery, so you have to use the buttons to turn the radio back on. Seems like a pain in the @$$ to me, but it’s a clients laptop not mine so he will have to live with that.
I hope this helps someone so they do not have to go through the frustration of trying to figure out why the radio has been turned off.
Oct 19, 2007 | Acer Aspire 3003LCi Notebook
Wi-fi PDA connectivity problem
First, restart your pda by using your stylus and pressing the pin-hole sized button on the back of the PDA. There are sometimes a couple of different reasons why the pda wont recognize the network. Main Reason: Make sure you are at the home screen... Tap the wifi icon on the lower right corner of the pda. T hen make sure that the WLAN power is turned ON. Press the setting button. If you see your network in the list, tap on it. It should bring up a network configuration window. Make sure it says it connect to "The Internet". Then tap on the "Network Key" tab at the bottom of window. If you have no security settings on your belkin router, make sure Authentication is set to Open and Data Encryption is set to "Disabled". Then press "OK". That should Be it!!!! Let me know if this way doesnt work, or if something doesnt make sence!
Sep 15, 2005 | Dell Axim X50v Pocket PC
Acer DX900 Smartphone Logo
261 people viewed this question
Top Acer Cell Phones Experts
Computer Repairing
Computer Repairing
Thomas Perkins
Thomas Perkins
Are you an Acer Cell Phone Expert? Answer questions, earn points and help others
