Question about Westinghouse SK-32H540S 32 in. LCD TV
Hooked up a dvd home theater to my westinghouse lcd tv, all good on the 1st day then there was no volume on tv next day. don't understand why speakers go out after a day. need help!!
  • 120 Answers
I would say to try to do a factory reset first. The way to do this is to enter the menu, go under the settings tab, and select the last option which is to reset. If this does not work try to unplug the TV for at least one minute, and finally the last option is to replace the main board. You can find out more information on price and availability for parts at parts@wde.com, also if you would like to further troubleshoot I can assist you if you send me your contact information to westytech@wde.com. If this information was helpful please rate me on this site.
Posted on Feb 03, 2010
    Problem Solver:
  • 13 Answers
The connector on the board from the speakers comes loose, this happened to me, easy fix, need a phillips screwdriver to take back off, and metal cage on back inside, then try replacing the 4 pin plug. You might have to bend it back a bit so it goes on more firmly then they originally put it on. let me know if ya need more help.
Posted on Feb 02, 2010
I want to connect my Craig electronics cht754 5.1 home theater with dvd to my emerson tv
It has nothing to do with how you hooked it up, It is just not compatible with that (TV) I hate to tell you,
Dec 02, 2012 | Audio Players & Recorders
IWhat's your problem? I have a Hisense LTDN42V68US LCD TV and I am trying to hook it up to a Phillips HDMI DVD Home theater surround system HT53544 my problem is I am not getting a sound I only get so
Good day!!!
Your problem is on your digital cable signal or connection..
Please check all the wirings and connection from the to cable box..
its better if you re insert all connectors and restart all TV,cable box....
Hope it helps...
Dec 06, 2011 | Televison & Video
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Panasonic SC HT940 home theater doesnt work with my LCD TV
the HDMI cable sends dato TO the TV, it does not have enuf bandwidth to send both to and from, just TO.
Dec 27, 2009 | Panasonic SC-HT940 System
Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
Jun 14, 2009 | Philips 32PF7421D 32 in. LCD HDTV
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Home theater hook up
Make sure u have plugged in the audio cable to the tv.
thanks..
Feb 01, 2009 | Westinghouse SK-32H240S Television
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
Westinghouse SK-32H540S 32 in. LCD TV Logo
70 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
