Question about GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven
My GE Advantium microwave internal fan is running continuously when the door is closed whether the unit is on or not. it began simultaneouly to when the interior lightbulb blew out. any ideas. have replaced the bulb (AGASIN!) and that has not solved the problem. thanks
  • 384 Answers
SOURCE: GE Advantium SCA1000DBB03 handle replacement
open door look at side there some are some screws remove them the outer door part will come off now don t be afraid to use screwdriver to help take it off good luck later
Posted on Apr 02, 2009
woobie dog
  • 1273 Answers
SOURCE: Need to replace halogen bulb that illuminates Advantium interior
Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
Regards! --W/D--
Posted on Jul 17, 2009
barkencoa
  • 3463 Answers
SOURCE: advantium noisy fan
It is probably the external cooling fan that is causing the problem, as this is usually the first one to come on, and the last one one to stop., and usually, these are located at the top of the unit.
Posted on Mar 22, 2010
kdrake84
  • 262 Answers
SOURCE: I have an advantium 220 that isn't microwaving.
If you have a hole on the magnetron cover then the magnetron is fried.
Typical G.E. microwave.
Same issue all the time.
Not worth replacing....maybe $150.00 to have a tech do it.
You can but a new microwave for $200.00 or under.
Keith
Posted on Feb 28, 2011
  • 405 Answers
SOURCE: My GE Profile Advantium Microwave
HI.If your timer button is a rotary. Timer switch button and if you gonna set and it runs however it does not stop.The timer switch button do mechanical control to stop the oven from working.So I suggests to check the timer inside the oven.The only way to stop is opening the door because the door will trigger the power source/button.So meaning the door connects to the power button.So check the timer inside it because it actually didn't work.Thank you for choosing FIXYA.
Posted on Jul 27, 2011
Do you have any directions to replace the upper heating element for a GE profile Advantium 120 model SCA100DBB93?
Hey Mary Lynn, .. with that unit not being manufactured any longer, it might be time to upgrade..IF you want to pursue replacement.. try here...
Ge Advantium Microwave Parts Fast Shipping RepairClinic com
Jun 19, 2017 | Ovens
Replace outside glass
You have an expensive Monogram microwave so you can expect the parts to be expensive also. The outer glass assembly by itself ballpark cost is about $160 and requires a complete dis-assembly of the door to replace since the screws are all inside. Then if you go by the book--- the door should be checked for microwave leakage after the repair which requires a special test meter. They also sell a complete door assembly at around $300 that comes completely assembled. You need to compare that cost against the age of your microwave and possibly a new unit which I think is still available. Either way its not a cheap fix.
Apr 11, 2015 | GE ZSC2001FSS Advantium Electric Single...
Scb2000 GE Advantium 240 microwave not heating
It s the magnetron tube, thats what makes the microwaves. Not a hard fix, you can order one from sundberg.com or marcone .com with your model number
Jul 19, 2012 | GE Monogram 30" 240 Volt Black Built In...
My GE Profile Advantium Microwave Oven runs (and heats) continuously. The only way to stop it from running is to open the door.
Hi
Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 27, 2011 | GE SCB2001FSS Advantium Electric Single...
How do I use this oven? Is it working correctly?
It would seem that the oven is small enough that a fan to flow the heat from the unit would be in use for both convection and bake modes. Usually convection ovens will have a "burst" of fan action during the bake process and it is not a steady fanning of the air that would dry out your cookies, ect. I have a small oven / microwave and my larger oven is a GE that has the "burst" convection that I described. Might not be that much help, but it's hard without more info on your unit. sometimes the model is behind the oven door.
Nov 04, 2009 | Jenn-Air Ovens
Apr 01, 2009 | GE SCA2001FSS Advantium Electric Single...
GE Advantium stopped working completely...indicates no power but it is on.
It may be that your high voltage diode or capacitor has shorted.
The fuse is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though it is bad!)
http://www.gallawa.com/microtech/xformer.html
To check the high voltage parts, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Dec 16, 2008 | GE Profile Advantium SCB2001KSS Stainless...
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven Logo
63 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
