Question about Hasbro iDog Electronic Pet Dog
My idog doesn't work - Hasbro iDog Electronic Pet Dog
I can't get my techpet to wirk
Instructions
    • 1 Check that the iDog is powered on if it doesn't respond to your commands. Press its nose to activate the toy.
    • 2 Verify that the iDog has fresh batteries installed if the dog doesn't turn on. Use a Phillips screwdriver to open the dog's battery compartment, located on the its right back leg. Insert two new AA-sized batteries according to the "+" and "-" symbols listed in the compartment.
    • 3 Inspect the iDog's connection to your iPod if it doesn't move and dance to your iPod's music. Plug the iDog's connector cable into your iPod. The cable end labeled "B" gets inserted into the headphone jack on your iPod. The opposite end goes into the front left leg of the iDog.
    • 4 Make sure your iPod is powered on if the toy is connected to the media player and is turned on, but not moving to the music. Your iPod may need recharged by connecting it to a computer with its included USB cable.
    • 5 Reset the iDog if it continually freezes or stops moving in the middle of a dance. Use the tip of a pen, paper clip or similar thin object to press the reset button located on the bottom of the toy's head.
Jan 20, 2013 | Toys
I want to buy this for my daughter for Christmas. Can it be connected to the idog so that it can play through the idog's speakers?
Yes if this has a headphone out it will work with idog.Will need cable to connect between the two.
Nov 11, 2010 | SanDisk Sansa Clip MP3 Player
My idog will not turn on. i just replaced the bat...
Try plugging in your iPod and playing music worked for me and/or put new batteries in it but do NOT press reset
May 20, 2010 | Hasbro I-DOG AMP'D
How to charge a idog
You don't "Charge" iDog AMP'D, you change the battery pack located under it's hind feet. When your iDog does the intro when you turn it on every five seconds, that means it's time for some new batteries!
Jun 28, 2009 | Hasbro I-DOG AMP'D
I had this Idog for a year and the battery was corroded and it won't work should i buy a new one?
Usually, if the corrosion is not that extensive, this problem can be fixed by sanding (such as with an emery board) the contacts in the battery compartment and cleaning them with rubbing alcohol.
Apr 22, 2009 | RTO Spi-dog Red In Box Idog Spider Man
Idog makes ipod malfunction??
There a lot of products out there that claim to be made for the ipod and other mp3 players. Usually, there are different problems;cheap, thin wiring sometimes can break. There can be loss of audio on the idog or any other speakers like fold out speakers. Cool or not, they are usually not well made. I had what I thought was a really nice set of speakers. Heh, after I plugged in the first time, my ipod was cracking in the speakers and the ear buds. Even though they are cool, light up, and are (what you think is) a good brand, it does't mean that it is well made. I suggest an Apple iHome.
Mar 25, 2009 | Hasbro I-DOG AMP'D
My iDog Portable won't play music!
try holding down his/her tail she/he may growl but then she/he will stop barking, it works on mine! :)
Feb 20, 2009 | Hasbro I-DOG AMP'D
Idog keeps dying!
The idog should not do that and i suggest returning it or exchanging it for another one.
Dec 31, 2008 | Hasbro I-DOG AMP'D
Idog hasn't been used in awhile.. Does it charge like an ipod?
You cant charge you just have to use batteries
Nov 12, 2008 | Hasbro I-DOG AMP'D
My idog amp'd wont play music.
is it connected to a ipod or zune or any mp3?
Oct 20, 2008 | Hasbro I-DOG AMP'D
Hasbro iDog Electronic Pet Dog Logo
247 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
