Question about Kitchen Ranges
Delay in oven ignition glow bar seems to work but oven doesn't ignite for approx. 20 min.
  • 619 Answers
Change the ignitor. Not drawing enough amps to open valve as needed.
Posted on Feb 02, 2010
The oven turns its self ON every 20 to 45 mins. The electric ignition glows and the gas comes on and burns for about 30 to 60 secs then turns off. The oven control knob is turned OFF. There are no aut
Seems to me you have a defective control panel board.. Ovens should never do this. Time for the Serviceman right away, this could be dangerous if you are not home.
Nov 24, 2014 | GE Kitchen Ranges
Oven igniter
Check with an appliance parts supplier to identify the oven and the correct igniter.
Jan 09, 2014 | Tappan TGF320 Gas Kitchen Range
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
GE profile Spectra gas range/oven is taking approx.20-30 min to preheat. Once it finally reaches temp. it seems to hold at that temp and maintain it. I have noticed occasional puffing sounds when it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 17, 2011 | Ovens
Oven does not start
Your glow bar igniter is probably burnt out. If you don't smell gas when turning it on that is OK since the glow bar igniters have a built in safety not allowing the gas to open without ignition. I bought a replacement igniter off ebay and wired it myself. Medium to easy handyman fix. Cost was less then $20 off ebay, but would have been $85+ elsewhere.
Jan 29, 2011 | Kenmore 33169 Gas Single Oven
GE HotPoint XL44 Gas Range Model RGB528
My bet is that the broiler ignitor has been out for a while and you just never knew it...
I would change the ignitor as a first try to fix it it is themost common failure..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 27, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My Maytag model # CGR3742BDW The broiler, cooktop work perfectly. The oven seems to never get the command to send gas to the burner. The "glow" pilot igniter works, just no gas.
Just because the igniter is working does not mean it is doing it's job. Very common for an igniter to glow but go bad so that it isn't sending current to the valve to open up. Igniter has to generate 3.2 amps to work the valve. Part # is 74007498 at a cost of approx. 80. to 90.00. Hope this helped.
Feb 03, 2010 | Ovens
Ka gas range the glow bar comes on but it takes sometimes 15 to 20 min before gas is supplied to burner in oven and finaly ignites
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 22, 2010 | KitchenAid KGST307 Gas Kitchen Range
Oven burner delays too much to light
Zanes, Your oven igniter is getting weak. The glowing bar next to the manifold must draw between 2.7 and 3.3 amps before the safety valve will acknowledge that it's actually hot enough to ignite gas and open up. Your igniter is most likely right at ~2.5 amps and the valve is "wanting" to open, but won't without some persuasion (hammer anyone?). The part number for your igniter is 9753108 and is available. Your local appliance parts house may not carry it, but there is a substitute that they WILL carry. Its' part number is WB2x9998. It's a universal flat igniter. Unplug the oven before repairing it, OK?
Aug 01, 2007 | KitchenAid KGRT607 Gas Kitchen Range
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
