Question about Maytag EPIC MFW9700S Front Load Washer
Maytag epic Z - error code f21 - will not spin or drain
4 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: I have a maytage epic front loader, its flashing
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3. Drain Filter
Check the drain filter for clogs as well. This filter can become clogged overtime, preventing the free flow to exit the drain tube. It is located inside the unit, mounted on the pump housing.
**The most common issue will be an obstructed hose or, line
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious within the actual control sector(Timer module or control board). It should be replaced i this case.
Posted on Nov 02, 2009
  • 1382 Answers
SOURCE: maytag epic z washer error code F21-have unplugged
F21 indicates a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump.
You may have something getting caught in the pump impeller and slowing it down. Or, you may have something clogging the drain lines. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If this solution doesn't solve your problem, you may have to replace the drain pump.The error code will continue to appear until the pump is replaced.
Thank you !!
Posted on Aug 01, 2010
  • 86 Answers
SOURCE: My maytag epic z is
Give this a shot:
http://www.fixya.com/support/t4027040-error_code_f21_will_not_spin_maytag_epic
Posted on Feb 06, 2011
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Maytag Epic Z Washing Machine shuts down during spin, can I fix it myself?
Hello Brain;
My name is Peter. I am a retired field service appliance technician.
Error codes are generalized. Both of your codes are drain relative. They will tell you to clean your drain, but there is more to it than that.
You may have a bad drain water level switch, a plugged drain line....
Please send me your model number, So I can see what your have.
Peter Goodwin
Glen Burnie, MD
Jan 13, 2015 | Maytag Epic Z and Performance Series 2000...
Maytag epic Z Washer shuts down at spin cycle
F21 usually indicates a pump problem however when that is not the problem then the place to look is the board itself as there is a mis communication between it and pump cycle? If the pump cannot operate it will not allow it to go into the spin.
F21 code how do you fix this
http://frontloadwasherguide.blogspot.com/2011/06/maytag-epic-and-epic-z-series-f21-error.html
Jan 12, 2012 | Maytag Washing Machines
Maytag epic z washer error code F21-have unplugged for 15 mins. and removed front panel and drained and found some coins and removed BUT it worked for a few mins. then the error code reappeared. what is...
Thank you !!
Aug 01, 2010 | Maytag Washing Machines
F21 ERROR CODE ON MAYTAG FRONT LOAD WASHER M#MHWE500VW
The newer model Maytag washers are manufactured by Whirlpool and have Whirlpool parts. If this is a Maytag Epic model washer, "F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as sock or under garments can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Dec 21, 2009 | Kitchen Ranges
I am getting error code F21
long drain time for the washer, it being an epic it should be under warranty call whirlpool at their toll free number depending where you live for free service
May 06, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
387 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
