Question about Car Audio & Video
Have a 96 dodge caravan just replaced the stock infinity stereo and still have same problem no door and back speakers.
  • 518 Answers
Hi, i know this will sound like a long job, but what you should do is check that all wires leading too and from your speakers have a good connection first before you dig deeper into this problem, as this could be the unit that is at fault, but check the connections first, Even test each speaker on another system so it eliminates each one.
Posted on Feb 03, 2010
Door speaker wiring (infinity)
Go to ( www.12volt.com ) sign up for free and it has auto wiring details.
Apr 10, 2014 | 1998 Dodge Grand Caravan
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
Stereo crackles
A little more detail. Do you mean speakers are crackling. Most likely blown the factory speakers. These are very cheaply made. And if you play music loud often they will blow easy. Is it completely stock system. If you relaced your stereo with an after market it may be the wrong ohms for the speakers or to much power and you need better quality speakes. If not coming in clearly make sure your antenna is tight and your wire harness are are connected securely. Let me know more details. Do you have infinity sound or not. Any after market components. Or completely stock.
May 02, 2013 | 2000 Dodge Ram 1500 Truck
Changed Radio - now speakers don't work. I took out the Chrysler radio that had a CD and cassette in it and replaced it with an aftermarket radio. Now the speakers don't work. I got the adapter from a...
Sounds like your Gr Caravan has the premium sound package. You likely haven't hurt anything - but you may need to modify the wiring a bit. The speakers have a tweeter speaker in the center of the main speaker and the wiring goes through that. However, it only worked with the premium package. Go in to the speakers and move the wiring connections from the tweeter to the main speaker. Your other option is to replace the speakers.
Jan 19, 2010 | 1994 Dodge Grand Caravan
My 2005 Montero with a Infinity stereo system has a blown woofer how can I fix this with after market speakers
Check to see what type of stereo head unit is installed in the car first and foremost... next you're going to want to find out if the unit is powered and sending power to the speakers.
After you figure this out, you can then go about picking out a replacement set of speakers for your car. You also need to decide if you want to upgrade being that you'll be spending money on new speakers anyway. Audio is a very subjective matter so what sounds good to you might not sound good to the next person which is why I recommend you go to a stereo shop and listen to the speakers yourself with all the settings on the head unit its hooked up to flat (i.e. the EQ flat, the fader off, the balance set to the center, and soforth) as this will give you a better gauge of how the speaker sounds by itself without any help from the head unit.
Infinity is a decent brand and Im sure you'll be able to find replacements of the OEM speakers relatively easily if you want to go that route. You could remove the speaker, and probably check out Crutchfield which stocks most of the infinity line for your specific model of Infinity woofers.
Removal is a simple task of removing door panels if its in the doors, and removing some screws and undoing some wire connectors. All you'll need are some screwdrivers and possibly some pliers.
Schematics and specifications of your stereo system should be easy enough to find online by doing a search with google or bing.
hope that helps! =)
Oct 17, 2009 | 2005 Mitsubishi Montero
Radio: replacing radio,not stock,have adapter connector, when hooked up radio pwrs up,but NO SOUND,somehow in mute,took to the"radio doctor", radio tests fine,& he saw how I had it hooked up, extra...
YOU WILL HAVE TO TRACE THE WIRES OUT, DO U HAVE A SEPERATE AMPLFIER? MANY OF THESE VANS DO, IF SO THAT IS THE PROBLEM.
HERE IS THE WIRING COLOR DIAGRAM FOR YOUR VAN
1998 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
Right Rear Speaker Negative Wire (-): Blue/White
Aug 06, 2009 | 1998 Dodge Grand Caravan
Power supply to in-door speakers 1996 grand caravan
I had this same problem. After reading other ideas and some trial and error, I finally got it. Most Caravans have an Infinity system (the speaker grill will say Infinity on it) ,which uses an amplifier to run the door and rear speakers. I had to ground the clip wire that was originally attatched to the strap ground on the factory installed radio. Then I also had to hook the wire on the new radio for power antenae (blue and white on my unit) to a blue wire on my new harness. This wire came from the last wire of 7 wire harness that had the other 6 wires for speakers. The original wire appeared to be green/red on my vehicle. After I connected both, the speakers cameon and sound great again
Jun 12, 2009 | 1996 Dodge Caravan
Dodge radio starts then shuts off
Hi Davis,
I had the same problem with Dodge Grand Caravan as well. I have a 2001 GCV and these radios go out all the time, plus each speaker has separate amps which some speaker will stop working. You will need a new stereo, however the dealership will charge you over $350 for the same replacement. I chose to go to BestBuy and buy a new Stereo for around $100 which has iPod connections which is a plus.
Next problem!!! Since each speaker has its own amp, in order to get the new stereo to work, I had to install a relay by tapping into the passenger side kicker panel master amp power supply to bypass the chip. Best Buy guy will know what to do. I suggest install the stereo yourself with a kit and go back to install an amp bypass relay switch. Hope that helps.
Stock Stereos **** and Dodge make is difficult to go aftermarket.....Good Luck
Apr 05, 2009 | 2001 Dodge Grand Caravan
Car Audio & Video Logo
207 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
