Question about Viper Vehicle Parts & Accessories
Why does Viper alarm remote buzz after I press any button? I must have pushed a button accidently while it was in my pocket and don;t know how to stop it from screaming each time I unlock or lock or remote start.
insanegtp
  • 112 Answers
SOURCE: I have a viper 5900 car alarm installed with remote start.
Look under dash for a small black box with wires coming out of it, about 2 or 3 inches rectangular.. there should be one or two screws on it. Look to see if it says which direction to turn for sensitivity. As far as not receiving, you need a new antenna, this is covered under warranty through DEI either bring back to where you purchased or look online and see where the closest dealer is to you...
Posted on Jan 29, 2009
  • 20 Answers
SOURCE: Viper 5900 remote start does not show it is off on the remote.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
Posted on May 22, 2009
SOURCE: How do I lock my keypad
there is a way to do it in the manual which can be found at www.viper.com/support.... i did it by mistake and now can't figure out how to turn it off
Posted on Nov 27, 2009
MECP Guy
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote start system just installed. When I use the remote to lock the car--there is no longer a chirp noise that confirms I hit the lock key. Thanks, Mary
I don't know which remote starter you have, but I have a Viper 5101. To fix this problem, I started the ignition, then turned it off, leaving the key in the ignition. I pushed the Valet button (it has a blinking blue light, mine is near my rear view mirror) and held it. Then, I pushed it 3 times, then held it down a 4th time. Then, I pressed the lock button once. I pushed the Valet button again to take it out of programming mode, and it worked! I got this sequence of steps from the installation manual online: http://www.scribd.com/doc/45065156/Installation-Viper-5101 Hope that helps!
May 12, 2011 | Remote Start System
Replaced truck battery and now remote doesnt work viper ce0890
Hello my name is Israel and I will be able to help you. First I will need for you to look for the alarm unit. The model you are giving me is for the remote not the alarm. Once you have this information, let me know and I will send you the instructions for programing the remote to the unit.
Feb 19, 2011 | Remote Start System
Just got my viper 5701 yesterday and the auto start on alarm worked perfectly. I woke up this morning and the auto start would not turn motor on. locks worked and everything. Took it back to dealer they...
The buzzing noise and lights blinking 5 times is part of the "Find my Vehicle" feature. This usually happens when/if you press the button too long. It takes a little getting use to, but keep practicing pressing the Remote Start button down for only a second or less... you should be releasing the button almost immediately after you hear it make the confirmation tone (meaning the vehicle has received the signal to start). If this doesn't help out, then you may need to go back and talk to your installer about trouble shooting!
Dec 16, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My friend has a 1998 chrysler sebring with a viper 160xv remote start. Everything has worked fine until a few days ago when it would not start. In order to start it you have to have the key in the on...
the problem isnt with remote starters, or with viper products. the problem is with under qualified persons attaining products they have no qualifications to operate.
TAKE THE CAR TO A DEALER(VIPER ALARMS) and they can fix the problem.
remote start was designed for people who want to start their car from afar and could actually comprehend that the multifunction remote was not only a keyfob to lock a door , or start a car, but it is also capable of remotely accessing certain programming features of the viper alarm, and whilst in some goofballs pocket........while he was sucking down goldslager was unintentionally reprogramming the viper alarm, and setting it into various modes of operation.
your lucky you didnt accidentally program it into carjack mode. lmfao
Jul 31, 2010 | 1998 Chrysler Sebring
Would like to know what the bottom 2 buttons mean on Viper 7153v
the bottom button is for function shift, and is used (with aux button) to activate certain functions (add on optional features like trunk pop, window roll up/down, rear defroster, etc--all depend on car and install) or by itself for status updates (interior temp check-press once, release, press and hold; remaining runtime-press and release three times, press and hold; lock status-press and release twice, press and hold). it is also used with lock and unlock for silent arm/disarm, and also to enter valet mode.
Feb 18, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Jan 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How to program viper 5701 remote
Unlock doors
Key out of IGN
Test unit
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Apr 01, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Dec 28, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
140 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
