Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Descale warning won't go away on DeLonghi Rialto after repair
I took a DeLonghi Rialto expresso machine in for repair (bad solenoid, as it turned out). When I got it back, the "descale" warning was on. I descaled using product they recommended, and the warning doesn't go away. I use deionized water in this unit, so I don't think it's a scale issue. I suspect that the "scale" sensor got unplugged in the repair. Is this something I an easily fix, or do I need to return it to the repair shop?
  • 2039 Answers
SOURCE: expresso machine
descaling gonna improved the pressure = stronger coffee and clean the inner boiler =warmer coffee but use descaler only not vinegar descaler melt calcium vinegar remove some calcium in littlt piece 1 part descaler 1 part water fill the water container open valve for a few second close it leave it for 15 minute and repeat untill empty after rince very good that stuff is corosif
THANKS FOR USING FIXYA
FROM MONTREAL CANADA PIERRE
Posted on Feb 18, 2008
SOURCE: descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Posted on Aug 17, 2008
kram26
  • 544 Answers
SOURCE: delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
Posted on Mar 21, 2009
Jeff the TV
  • 82 Answers
SOURCE: Need descaling instructions for EAM 4500 auto espresso machine
use 1/4 cup of vinegar and fill pot with cold water, run through machine
Posted on Aug 01, 2009
  • 20 Answers
SOURCE: descaling a Saeco InCanto deluxe
Press and hold the descale button(lower right), it will light up.Then you can start the process. The machine will prompt the next step when the solution in the tank is used up. Have a go.
Posted on Dec 23, 2009
My Coffee machine Delonghi doing expresso without foam today. Before doing good expresso with foam. help please.
Espresso should have crema not foam, foam is air added to coffee, like Starbucks does. Issue lays in the grinder and coffee quality. Recommend using Italian espresso bean like Miscela d Oro
Apr 14, 2014 | DeLonghi Coffee Makers & Espresso Machines
Tip
How to descale espresso machines.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Here is a basic generic picture of a espresso system of how they work.
I hope this helps. Feel to contact me for addition questions. Thanks Mike
on Jul 26, 2011 | Coffee Makers & Espresso Machines
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Jun 29, 2011 | Microwave Ovens
Hot water tap no longer works. Cleaned out deposits and it still only drips out. What needs to be done. I fear the boiler is corroded or the tap is blocked with calcium despite the water filtering system....
Because the hot water spout is controlled by gravity, it is partially clogged, Here is a little story and see if this helps,Let me know
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
Jun 23, 2011 | Bunn VLPF Coffee Maker
How do you descale the machine,as we have no manual
Jun 14, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
The CLEAN light has come on. How do I clean it?
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
How to clean coffee machine properly? i was given one and want to ensure that it is save from "everything" so i can start using it.
Jun 09, 2011 | Coffee Makers & Espresso Machines
Delonghi rialto. i need a manuel and video
I'm not sure if there is a specific model number on yours. But here is a link to a DeLonghi Rialto 4500. http://www.starbucksstore.com/images/products/pdf/4_Rialto_Espresso_Machine.pdf
Feb 27, 2010 | DeLonghi Coffee Makers & Espresso Machines
Aug 01, 2009 | Coffee Makers & Espresso Machines
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
212 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
